Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
504 Discussions
Component failed functional test not able to boot up. Board passed after changed new component
SAkwa
Part#: AE1822-5429LF
Desc: IC PLD FPGA unprogrammed 5CSE 672-UBGA
Issue: Component failed functional test not able to boot up. Board passed after changed new component.
MPN: 5CSEBA5U23C7N
Supplier: ARROW ASIA DISTRIBUTION LIMITED
Qty: 2pcs
PO#4514872849 (DATE CODE 1849)
PO#4514769316 (DATE CODE 1737)
Zawani_M_Intel
Dear Saraa Akwannadin,
I am Wani who will support your case.
Please tell me the story of this part. How you discovered this failure?
Or maybe some other details can help me to understand more about your case.
1. What is the failure symptom? Please elaborate the failure symptom in detail.
2. Where did the failure happen?
3. Does the failure unit ever working before failure?
Thank you!
Wani
*Please consider of confidential information you may share publicly. You can let me know if you need to send confidential information through private message.
SAkwa
Hi Wani,
Please refer to below.
How you discovered this failure? – It failed both our ICT and FCT test that show this part failed. Able to pass the test after changed with new part.
1. What is the failure symptom? Please elaborate the failure symptom in detail. – At ICT it will failed open, while in FCT LED pattern will show this part failed
2. Where did the failure happen? - At ICT and FCT
3. Does the failure unit ever working before failure? - No, the failure unit originally failed.
Kindly always loop in below email for your answer notifications.
nagentheran.m@venture.com.sg
noorazreen.aris@venture.com.sg
norhafizah.bohari@venture.com.sg
SAkwa
Hi Wani,
Any update for ERMA#?
Zawani_M_Intel
Hi SAkwa, I deeply apologize for late response as I expecting some system migration. I take noted on your statement ‘At ICT it will failed open, while in FCT LED pattern will show this part failed’. Can you help to provide which pins involved? Regards, Wani
SAkwa
Hi Wani,
The suspected pins that failed was U1.B18, U1.B14.
Zawani_M_Intel
Hi SAkwan,
I like to know more about the failure. However it might require some confidential detail. Let's continue the communication through our private message.
Thanks!
Wani
Zawani_M_Intel
Dear SAkwan,
Anticipating the case has been resolved and the final report has been delivered, the case will be set as close.
I am really happy to work with you again in future.
Thank you!
Wani
