Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
504 Discussions
Creating PCB based on 10M08 Evaluation Board but with other MAX10 FPGA
Iukas
Hello everyone,
for a school project, I want to design a PCB for / around the MAX 10 FPGA. As I'm trying to make my life easier, I am using this (https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/max/10m08-evaluation-kit.html) Intel Evaluation Board as a starting point. the FPGA used in the design is the 10M08SAE144C8G. However, it has only 8000 LE, which will not be enough, therefore I'm planning to use 10M16SAE144C8G as a (hopefully) drop in replacement. I think that this will work, why shouldn't it?
All it really is, is a PCB which uses the same layout, but with more of the available GPIOs broken out and preferable the mentioned 10M16SAE144C8G (or even 10M25SAE144C8G). I checked the pinout of both FPGAs and they are the same. Also programming should be the same as far as i know.
Thanks for reading!
Farabi
Hello Lukas,
I am taking over this case from previous owner.
You may refer to : https://www.intel.com/content/www/us/en/docs/programmable/683658/current/i-o-vertical-migration-support.html
Part number you are using is in the vertical migration list. So the replacement should be drop-in replacement. Just change the part number in your Quartus project file and re-compile.
regards,
Farabi
