Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
504 Discussions
Difference between Open Access OFS and the OFS under otcshare
Beginner_in_FPGA
Hey,
Intel provides 2 OFS stacks,
I wanted to know if there is any difference between the two as they offer the same features in terms of throughput.
The Open source OFS seems to support more boards than otcshare.
Thank you.
khtan
The public release OFS (https://ofs.github.io/ofs-2024.1-1/)  is the official OFS documentation and source for references moving forward.
Previously we have the otcshare which contains limited release(including development release) for certain users only. Basically both of them are similar (though i think otcshare might have older versions of OFS), in fact ofs.github.io will contain more updated release and documentation thus it is recommended to refer to the official ofs.github.io for OFS related materials.
Kian
Beginner_in_FPGA
Hi @khtan ,
So the design implemented within the otcshare is an older version of ofs if I'm not wrong, correct?
So if I were to program the N6000 board I could use both of them, but preferably use OFS (https://github.com/OFS/ofs-agx7-pcie-attach) rather than OTCshare (https://github.com/otcshare/intel-ofs-fim/tree/release/n6000-beta3.2-SKU1).
Best Regards
khtan
I was checking on the otcshare version , basically it would be hard to say it is always older version only as otcshare is also used for pre-release development version that is based on a single board with fixed customization whereas public release OFS repo have the released official version for public to use with added functionality OFSS for board customization and to cater for more board variants. (eg both otcshare and public OFS repo have 4.1.1 and 24.1.1 respectively which is the same version but otcshare only for N6001 board only).
Thus my advice is to use the publicly OFS repo as it offers more functionality and board specific customization.
KH
Beginner_in_FPGA
Hi @khtan ,
Okay got it, thank you for the confirmation. This case can be closed now.
Best Regards.
khtan
Thanks, I will set this thread to close pending. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 4 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Kian
