Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
504 Discussions
Error (19877): Partial reconfiguration no longer supports synthesis revisions when trying to synthesize example design
GDUFO2
On my Intel DevCloud FPGA server, I trying to synthesize the following example:
/opt/a10/intelrtestack/a10_gx_pac_ias_1_2_pv/hw/samples/hello_afu
following the instructions provided in the README file.
I get the following error:
Error: Flow failed:
Error: Quartus Prime Synthesis was unsuccessful. 2 errors, 9 warnings
How can I fix that?
GDUFO2
Side Note: The server is configured with following Quartus version:
Info: *******************************************************************
Info: Running Quartus Prime Shell
Info: Version 18.1.0 Build 222 09/21/2018 SJ Pro Edition
RichardTanSY_Altera
Sharing your design and the readme file may help to further understand.
You could refer to below KDB and check whether the workaround works for your case.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/embedded/2018/error--19877---partial-reconfiguration-no-longer-supports-synthe.html
GDUFO2
Hi Richard,
I've already took a look at your link, it does not give any guidance on how to update the example design from Intel.
You can download the example design from this LINK
Best
GDUFO2
Hi Richard,
Any news on that topic?
Best
