Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
504 Discussions
FPGA AI Suite installation issue
GuillermoH
Good morning,
I am trying to run the dla compiler with Intel FPGA AI Suite version 2023.1 but I am getting this error:
dlac: error while loading shared libraries: libinference_engine_transformations.so: cannot open shared object file: No such file or directory
I actually checked that this file does not exist on my machine. I would like to kindly ask for some help regarding the following questions:
-Is this library needed in the Intel FPGA AI Suite version?
-If it is needed, how can I obtain it?
Thank you very much in advance for your help,
Best,
Guillermo
JohnT_Intel
Have you install the OpenVINO in your system? You may follow the installation flow from https://www.intel.com/content/www/us/en/docs/programmable/768970/2023-2-1/installation-overview.html.
GuillermoH
Hi John,
Thanks for your reply. Yes, I have OpenVINO (version 2023.0.2) installed in my system.
Best,
Guillermo
JohnT_Intel
So after having the OpenVINO, it is still not working? Have you set your environment correct?
GuillermoH
Yes I have. But I would like to know if libinference_engine_transformations.so library is needed by the Intel FPGA AI Suite version 2023.1 or OpenVINO version 2023.0.2. And if it is needed, how can I obtain it?
JohnT_Intel
You will need to have install both on the system.
You may refer to the installation flow in https://www.intel.com/content/www/us/en/docs/programmable/768970/2023-2-1/installation-overview.html.
GuillermoH
Hi John,
As I mentioned previously, I have both Intel FPGA AI Suite version 2023.1 and OpenVINO version 2023.0.2 installed on my system. I also have my environment set correctly. Please I kindly ask you to not send me again the installation flow link, as this was already done before I opened this issue. What I need to know is why I get an error complaining about a missing library libinference_engine_transformations.so when running the dla compiler.
JohnT_Intel
Can you try to check your system to see if the file is available in "/opt/intel/openvino/inference_engine/lib/intel64 /"? If you install in different directory then try searching into your openvino directory.
