Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
504 Discussions
How to update The FIM and BMC firmware for 2 INTEL PAC on same server
User1582192733150209
Hello Sir/Madam,
Our server has 2 same Intel PAC Arria10 inserted.
When I check the cards using fpgainfo fme and found one of the BMC is not showing correct as below
[root@fig01 a10_gx_pac_ias_1_2_pv]# fpgainfo fme
Board Management Controller, microcontroller FW version 26889
Last Power Down Cause: POK_CORE
Last Reset Cause: None
//****** FME ******//
Object Id                    : 0xED00001
PCIe s:b:d:f                 : 0000:D8:00:0
Device Id                    : 0x09C4
Socket Id                    : 0x00
Ports Num                    : 01
Bitstream Id                 : 0x123000200000185
Bitstream Version            : 0x557B00030201
Pr Interface Id              : 69528db6-eb31-577a-8c36-68f9faa081f6
Board Management Controller, microcontroller FW version unavailable
Last Power Down Cause: unavailable
Last Reset Cause: unavailable (can't open)
Object Id                    : 0xED00000
PCIe s:b:d:f                 : 0000:3B:00:0
Device Id                    : 0x09C4
Socket Id                    : 0x00
Ports Num                    : 01
[root@fig01 a10_gx_pac_ias_1_2_pv]# lspci |grep 09c4
3b:00.0 Processing accelerators: Intel Corporation Device 09c4
d8:00.0 Processing accelerators: Intel Corporation Device 09c4
I was trying to update the FIM to latest version but failed as below, information in the last row mentioned the FIM version is already the latest one.
But from the output of fpgainfo FME , that is not true. Any suggestion is welcome. Thanks! Jim
[root@fig01 a10_gx_pac_ias_1_2_pv]# ./setup_fim_and_bmc.sh -b 3b -d 0 -f 0 -p $OPAE_PLATFORM_ROOT
Pre-requisites
1. Intel FPGA driver and OPAE must be installed
2. Bittware Tools must be installed
           CentOS tool version: sudo yum install bw2tk-lite-2018.4.0.el7.x86_64.rpm
           Ubuntu tool version: sudo dpkg -i bw2tk-lite-2018.4.0.u1604.amd64.deb
           Bittware tools must be added to PATH; export PATH=/opt/bwtk/2018.4.0L/bin/:$PATH
3. Only one PAC card must be connected to the host server using the Intel FPGA Download cable
4. Do not interrupt the script flow, this could brick the board
!!!Exit(Ctrl- C) and Refer to the Intel Acceleration Stack for Intel Programmable Acceleration Card with Intel A10 GX FPGA Quick Start Guide if above steps are not completed
Do you want to continue with the FIM and BMC upgrade? (Y/n):
Two part install process:
Part 1: Install FIM and program BMC application
<Power Cycle>; reboot is not sufficient
Part 2: Install BMC bootloader and update remainder of BMC application
Please type a selection or press Enter to accept default choice [ 1 ]:
Provide directory path to BMC firmware and Bootloader: /root/inteldevstack/FPGA
Multiple PAC cards on system is not recommended. Exit script if PAC's can be removed
Do you want to continue? (Y/n): y
>>> Running cmd:
     bwconfig --scan=usb
Scanning for devices
[result]: Board Type (Name),  Serial, VendorID, DeviceID, USB-Address
[0]:     0x5f (A10SA4)       203245 0x2528   0x0005   0x7
You have the latest FIM. To update to latest BMC, downgrade to FIM version 1.1PV and rerun the script to install latest FIM and BMC
JohnT_Intel
Based on the message provided, you are connecting the USB-Blaster to only 1 of the device. Could you confirm that the blaster is connected to the board with older BMC? If no, please change the blaster to that board.
Dear JohnT,
thanks for your suggestion, which is very useful.
just like you mentioned ,there is only 1 USB blaster connected to one of them, but I do not know how to match the physical card with PCIE bus number?
Is there any diagnosing program I can use to know which PCIE Pac CARD has USB connection, because server is in remote location, from phisical view I can not match PCIE BDF with specific card.
I have tried 2 diagnosing program nlb_3 and DMA_AFU for both these 2 cards, totally 4 test cases worked correctly, I guess that is because that examples running use PCIE to download gbs, and does not involve usb-JTAG.
thanks
Jim​
JohnT_Intel
From the "fpgainfo fme" print out, you have 2 cards. So now you need to change the blaster to the 2nd card in order to performed the upgrade.
Dear JohnT,
thanks for your suggestion, I will do it.
without FMC updating to correct version ,I thought that card would faled with diagnosing program running, but did not, any potential influence if that card faild to upgrade to correct FMC version?
thanks
jim ​
JohnT_Intel
From the "fpgainfo fme", the FIM is updated but not the BMC. So you will need to make sure that the BMC is also updated to make it work correctly.
Dear JohnT,
well noted and thanks for your valuable suggestion.
best regard
Jim
JohnT_Intel
No problem. Let me know if the issue is still observed.
