Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
504 Discussions
Intel FPGA AI Suite PReLU layer error
RubenPadial
I'm using Intel FPGA AI 2023.2 on ubuntu 20.04 host computer and trying to infer a custom CNN in a Intel Arria 10 SoC FPGA.
Due to some accuracy drops, I replaced the ReLU activation layers with the PReLU activation layer in my mode, supported by the Intel FPGA AI Suite.
The IR model is generated, but the accuracy drops from 97.46% to 63.20%. The model optimizer function is as follows:
mo
--saved_model_dir "{path_savedModelPath}"
--input_shape "{lst_inputShape}"
--model_name "{str_modelName}"
--output_dir "{path_irTargetPath}"
--use_new_frontend
Please note that --use_new_frontend is used, but the IR model is not generated otherwise.
The architecture is A10_FP16_Generic.arch. The options used for dla_compiler are as follows:
dla_compiler
--march "{path_archPath}"
--network-file "{path_xmlPath}"
--o "{path_binPath}"
--foutput-format=open_vino_hetero
--fplugin "HETERO:FPGA,CPU"
--fanalyze-performance
--fdump-performance-report
--fanalyze-area
--fdump-area-report
But the graph is no compiled and the following error is displayed:
Layer (Name: StatefulPartitionedCall/model/p_re_lu_7/add_0_48_result, Type: Result) WRONG MESSAGE: Layer (Name: StatefulPartitionedCall/model/p_re_lu_7/add, Type: Eltwise) WRONG MESSAGE:
Layer (Name: StatefulPartitionedCall/model/p_re_lu_7/mul, Type: Eltwise) is not supported:
FPGA plugin: 'Constant' nodes are not supported as input of nodes Eltwise
Layer (Name: StatefulPartitionedCall/model/p_re_lu_7/Relu_1, Type: Relu) WRONG MESSAGE:
Layer (Name: StatefulPartitionedCall/model/p_re_lu_7/Neg_1, Type: PowerIE) WRONG MESSAGE:
Layer (Name: Constant_2809, Type: Constant) is not supported:
Error occurred.
../compiler/aot_plugin/src/dla_executable_network.cpp:134 Graph is not supported on FPGA plugin due to existance of layer (Name: StatefulPartitionedCall/model/p_re_lu_7/mul, Type: Eltwise)
in topology. Most likely you need to use heterogeneous plugin instead of FPGA plugin directly.
Find the model in the following link https://consigna.ugr.es/?s=download&token=11ed96b6-769d-4875-b8c7-0b73c1d0149a
Same problem still present in OpenVINO 2022.3.1 + Intel FPGA AI Suite 2023.3
JohnT_Intel
The link provided is not working as it is showing missing token.
RubenPadial
@JohnT_Intelit works. The token is in the link.If you encounter difficulties downloading it, could you please provide an alternative method for securely sending files with a size exceeding 71MB?
JohnT_Intel
I am able to download it. Sorry for the confussion.
JohnT_Intel
Is it possible to try other arch? Or you would like to only use generaric.arch file only?
JohnT_Intel
Is there a chance to try different type of bitstream to see the result?
RubenPadial
Hello @JohnT_Intel,
It has been already tested.
JohnT_Intel
Can you list out the architecture use and what is the differences observed?
JohnT_Intel
JohnT_Intel
Anticipate your reply
JohnT_Intel
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
