Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
459 Discussions
Latest BPS for Stratix 10 on Quartus prime pro 18.1 .0.222 ???
zjinf
  1. my environment is:
board: Stratix 10 development board
aocl: aocl 18.1.0.222 (Intel(R) FPGA SDK for OpenCL(TM),
2.my question is :
In diagnose hint , it says my board is s10gx_ea
in my :intelFPGA_pro/18.1/hld/board/s10_ref/hardware directly , it only has s10gx , no s10gx_ea
Can any body give me an available s10gx_ea .bps(s10_ref package ) file match aocl 18.1.0.222 (Intel(R) FPGA SDK for OpenCL(TM)
Thanks very much!!!!!
MuhammadAr_U_Intel
Hi, Per my understanding BSP "s10gx_ea" is delivered with OpenCL version 18.0 you can download it from "http://fpgasoftware.intel.com/opencl/18.0/?edition=pro&download_manager=dlm3" As for compiler version 18.1 please use BSP from installation directory BSP named "s10gx" Hope this clarifies. Arslan
zjinf
HI MUsman
Thanks for your reply!
if use s10gx bps, when i run the openCL example, it says that:" the aocx file is for s10gx while my board is s10gx_ea", it does not match each other ! how to fix it ????
zjinf
Querying platform for info:
CL_PLATFORM_NAME                        = Intel(R) FPGA SDK for OpenCL(TM)
CL_PLATFORM_VENDOR                      = Intel(R) Corporation
CL_PLATFORM_VERSION                     = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 18.1
Querying device for info:
CL_DEVICE_NAME                          = s10gx_ea : Stratix 10 Reference Platform (acls10_ref0)
CL_DEVICE_VENDOR                        = Intel(R) Corporation
CL_DEVICE_VENDOR_ID                     = 4466
CL_DEVICE_VERSION                       = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 18.1
CL_DRIVER_VERSION                       = 18.1
CL_DEVICE_ADDRESS_BITS                  = 64
CL_DEVICE_AVAILABLE                     = true
CL_DEVICE_ENDIAN_LITTLE                 = true
CL_DEVICE_GLOBAL_MEM_CACHE_SIZE         = 32768
CL_DEVICE_GLOBAL_MEM_CACHELINE_SIZE     = 0
CL_DEVICE_GLOBAL_MEM_SIZE               = 2147483648
CL_DEVICE_IMAGE_SUPPORT                 = false
CL_DEVICE_LOCAL_MEM_SIZE                = 16384
CL_DEVICE_MAX_CLOCK_FREQUENCY           = 1000
CL_DEVICE_MAX_COMPUTE_UNITS             = 1
CL_DEVICE_MAX_CONSTANT_ARGS             = 8
CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE      = 536870912
CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS      = 3
CL_DEVICE_MEM_BASE_ADDR_ALIGN           = 8192
CL_DEVICE_MIN_DATA_TYPE_ALIGN_SIZE      = 1024
CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR   = 4
CL_DEVICE_PREFERRED_VECTOR_WIDTH_SHORT  = 2
CL_DEVICE_PREFERRED_VECTOR_WIDTH_INT    = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_LONG   = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_FLOAT  = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_DOUBLE = 0
Command queue out of order?             = false
Command queue profiling enabled?        = true
Using AOCX: hello_world.aocx
Context callback: Program was compiled for a different board.
      aocx is for board s10gx whereas device is s10gx_ea
Use aocl program to safely transition to the new board
Segmentation fault (core dumped)
MuhammadAr_U_Intel
I believe issue here is your board flash is programmed with older image (18.0) however latest .aocx is build with new compiler build (18.1)
Try updating the flash by aocl flash <acl0> <new.aocx>
Hope this helps.
Arslan
zjinf
  1. with 18.1 (s10gx) aocl install by root . after aocl install command , when i run "aocl diagnose " command, it can't detect the board (but aoc command can generate s10gx *.aocx file ),DIAGNOSTIC_FAILED, can't detect device , I can do nothing.
and i turn back to (s10gx_ea), it can diagnose successful.
2 . after aocl flash acl0 <my_s10gx.aocx> successfully , i still can't run the host file .
all i did just flow the "S10_DevKit_Initialization_18.1.pdf" in intelFPGA_pro/18.1/hld/board/s10_ref/bringup directory
MuhammadAr_U_Intel
Hi, Problem here is mismatch in aocx file vs BSP. Stratix10 BSP provided with OpenCL SDK version 18.0 is for Engineering sample Device (s10gx_ea) to continue using it you have to generate .aocx files using the OpenCL SDK version 18.0 However Stratix10 BSP provided with OpenCL SDK version 18.1 is for Production device (s10gx), it might not work with you board which is Engineering sample device. Thanks, Arslan
