hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
495 Discussions
PAC S10 board(D5005) Alt_sld_fab_0.alt_sld_fab_0: add_instance: Can't create component type altera_sld_agent_endpoint_tieoff Error opnening .../ipgen/alt_sld_fab_0/alt_sld_fab_0.ip
SPour2
When I am trying to synthesis ethernet example (eth_e2e_e10) for PAC S10 board(D5005) I am getting the following error. Could somebody help me?
Error (11176): Alt_sld_fab_0.alt_sld_fab_0: add_instance: Can't create component type altera_sld_agent_endpoint_tieoff
Error (11176): Error opening /root/shameer/eth_e2e_e10_1/build_synth/build/qdb/_compiler/afu_default/_flat/19.2.0/partitioned/1/.temp/sld_fabrics/ipgen/alt_sld_fab_0/alt_sld_fab_0.ip.
Detialed messages from syntheziser :
Info (11172):    invoked from within
Info (11172): "add_instance sldfabric_t0 altera_sld_agent_endpoint_tieoff"
Info (11172):    ("eval" body line 7)
Info (11172): "eval $tcl"
Info (11172):    (procedure "compose" line 36)
Info (11172): "compose"
Info (11172): "interp eval $slave {
Info (11172): Compose
Info (11172): }"
Warning (11175): Alt_sld_fab_0.alt_sld_fab_0.alt_sld_fab_0.splitter.nodes: Interface has no signals
Error (11176): Alt_sld_fab_0.alt_sld_fab_0.alt_sld_fab_0.ocpfabric.clock: ocpfabric.clock must be connected to a clock output
Info (11172): ***************************************************************
Info (11172): Quartus is a registered trademark of Intel Corporation in the
Info (11172): US and other countries. Portions of the Quartus Prime software
Info (11172): Code, and other portions of the code included in this download
Info (11172): Or on this DVD, are licensed to Intel Corporation and are the
Info (11172): Copyrighted property of third parties. For license details,
Info (11172): Refer to the End User License Agreement at
Info (11172):
Info (11172):
Info (11171): Finished IP generation for the debug fabric: alt_sld_fab_0.
Error (19882): Automatic debug logic insertion has failed.
Error: Flow failed:
Info (144001): Generated suppressed messages file /root/shameer/eth_e2e_e10_1/build_synth/build/output_files/afu_default.syn.smsg
Error: Quartus Prime Synthesis was unsuccessful. 5 errors, 127 warnings
   Error: Peak virtual memory: 6236 megabytes
   Error: Processing ended: Sun Jan 12 17:02:08 2020
   Error: Elapsed time: 00:01:23
Error (293001): Quartus Prime Full Compilation was unsuccessful. 6 errors, 127 warnings
Error (23035): Tcl error: ERROR: Error(s) found while running an executable. See report file(s) for error message(s). Message log indicates which executable was run last.
   while executing
"execute_flow -compile "
   (procedure "compile_pr_revision_impl" line 8)
   invoked from within
"compile_pr_revision_impl $impl_rev_name"
   (procedure "compile_pr_revision" line 11)
   invoked from within
"compile_pr_revision $options(impl)"
   (procedure "main" line 87)
   invoked from within
"main"
   invoked from within
"if {($::quartus(nameofexecutable) == "quartus") || ($::quartus(nameofexecutable) == "quartus_pro") || ($::quartus(nameofexecutable) == "qpro")} {
   (file "./s10_partial_reconfig/flow.tcl" line 581)
   while executing
   invoked from within
   invoked from within
   invoked from within
"main"
   invoked from within
Error (23031): Evaluation of Tcl script ./s10_partial_reconfig/flow.tcl unsuccessful
Error: Quartus Prime Shell was unsuccessful. 12 errors, 127 warnings
   Error: Peak virtual memory: 1306 megabytes
   Error: Processing ended: Sun Jan 12 17:02:11 2020
   Error: Elapsed time: 00:01:32
Quartus build failed
SengKok_L_Intel
Hi ,
May I know if you are using DCP 2.0.1? If yes, there is no 10G LL MAC example design.
Regards -SK
SPour2
Thanks for the reply.
Yes, I am using DCP 2.0.1. I didn't see eth_e2e_e10 example in samples folder of DCP 2.0.1 installation path.
But I have to transfer data through ethernet port of S10 PAC.
So I took eth_e2e_e10 example from 2.0.b339 and trying to fix errors.
Is there any example for ethernet data transfer along with DCP 2.0.1?
SengKok_L_Intel
The DCP2.0.1 is not supporting the LL MAC 10G example design, this is why you can't find it in the package. It won't work if you copy the example design from the old version package. I will check with the Intel Marketing team, and see if there is other Ethernet design available for the DCP2.0.1 that can release.
Regards -SK
SengKok_L_Intel
FYI, there is a plan to have the third party Ethernet MAC design work with DCP 2.0.1, but the detail will only be available in the next couple of weeks.
Regards -SK
SPour2
Thank for the info. Please let me know the details as and when it avaialable.
SengKok_L_Intel
Sure, I will provide you more info once this is available.
Regards -SK
SengKok_L_Intel
I would suggest you contact your local Intel FPGA sales representative for requesting the third party MAC for DCP 2.0.1. This is because more detail information is required (e.g customer contact detail, number of licenses and maybe the pricing) in order to distribute the license and IP.
Regards -SK
