Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
504 Discussions
Quartus Altera installed on client computer does not see floating license on remote server
VFrid1
Hello
Quartus Altera installed on client computer does not see floating license on remote server .I get error Requests from the same USER/HOST/DISPLAY do not consume a new license
See part of log diagnostic file from LMTOOLS
This license can be checked out
"6AF7_00D8" v2016.12, vendor: alterad, expiry: 1-jan-0
 License server: tentafs.mksinternal.com
 floating license no expiration date
"6AF7_00D8" v2020.01, vendor: alterad, expiry: 1-jan-0
"6AF7_00D8" v2021.03, vendor: alterad, expiry: 1-jan-0
"6AF7_0014" v2016.12, vendor: alterad, expiry: 1-jan-0
"6AF7_0014" v2020.01, vendor: alterad, expiry: 1-jan-0
"6AF7_0014" v2021.03, vendor: alterad, expiry: 1-jan-0
"6AF7_0034" v2016.12, vendor: alterad, expiry: 1-jan-0
"6AF7_0034" v2020.01, vendor: alterad, expiry: 1-jan-0
"6AF7_0034" v2021.03, vendor: alterad, expiry: 1-jan-0
How fix this issue and what does it mean ?
AR_A_Intel
Hello
Welcome to INTEL forum. Could you kindly help check you license setup again. Starting with your OS support, whether your machine is supported or not (OS) by referring to link below:
https://www.altera.com/support/support-resources/download/os-support.html
Make sure the port used by license server or vendor daemon is not blocked. The port number is required for Windows systems and should be outside of the 27000-28000 range and be unique on the machine. The following example shows how to specify port numbers in a floating license file. example, specify ports 1800, 1801, and 1802.
SERVER myServer 0123456789ab 1800
VENDOR alterad ./alterad port=1801
VENDOR mgcld ./mgcld port=1802
My suggestion would be:
1)     After VPN connection is established, setup license path in Quartus II>>tools>>license setup.
2)     Verify license server is running by using “lmutil lmstat –a –c <port>@<server> in BOTH server and client machine.
3)     Ping license server via VPN or telnet <host>< port> to check the TCP connection is established
Please stop and restart the server. You need to allow the firewall access to the port number from both server and client machine.
You can also refer to link below for more detailed instructions for Setting up a floating network license server (page 37 of 59):
https://www.altera.com/content/dam/altera-www/global/en_US/pdfs/literature/manual/quartus_install.pdf
You can also refer this following YouTube for license setup. https://www.youtube.com/watch?v=Ob9ei5lMgG
You can also refer to this following YouTube on Setting up and debugging Quartus floating licenses.
https://www.youtube.com/watch?v=llLaWatUbe8
 Let me know if this information is helpful.
VFrid1
Hello
An issue is happened in local  network as well and where is no firewall.
The temporary license works properly .
Could you check attached permanent license
