Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
Register without clk signal.
HaiDs
I am trying to create a register as shown in the picture so that there will be only memory storage.
I want it to have only a enable line that will only be enabled when I press the key.
The problem is that when I put it in the sensitivity lines of the process the compiler gives me a warning claiming that the key is not a clock line.this is actually what happend.this is actually what happend.this is the goalthis is the goal
SyafieqS
Hi Hai,
May I know if there is any update on this?
HaiDs
So basically I don't know how to create a Flip Flop. D latch. I thought of using the WHEN statement. but I don't see the FF in RTL viewer,
SyafieqS
Hi Hai,
You can refer to template to create Flip flop and register in insert template->verilog hdl->altera primitive-> fliflop/register. This a synthesizable code for Quartus which would help you to easier create FF with template.
