Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
504 Discussions
Remote debug AFU on-chip memory using System Console.
khyam
I have designed AFU with on-chip memory. I am doing remote debug of AFU using mmlink, system console, and signal tap.  I want to read and write the on-chip memory using the system console(remote method, that is TCP, the SLD hub controller).  I am using the following command to communicate on-chip memory using the system console.
1)
cmd: get_service_paths device
rsp: /devices/1
2)
 cmd: set m_path [lindex [get_service_paths master] 0 ]
rsp: /devices/1/(link)/TCP/sld_hub_controller_system_0_fabric.h2t_0/sld_hub/(110:132 v1 #0)/phy_0/master
3)
cmd: set c_path [claim_service master $m_path ""]
rsp: error: claim_service: Could not claim service at /devices/1/(link)/TCP/sld_hub_controller_system_0_fabric.h2t_0/sld_hub/(110:132 v1 #0)/phy_0/master: Channel(s) have already been claimed, and the new claims are not compatible with the existing claims(s).
    while executing
"claim_service master $m_path """
    invoked from within
"set c_path [claim_service master $m_path ""]"
I got the above error when using the claim_service command to claims the service for exclusive use.
Even for the open_service command also I am getting the same error.
Could you please provide the solution to the above issue?
RichardTanSY_Altera
Hi @khyam
I am not familiar with AFU and I believe the document guide here helps to provides some guidelines on how to remote debug AFU.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/afu-developers-guide.pdf
  • System Console must be started after launching the mmlink application. If System Console returns an error, close the mmlink application, re-invoke mmlink, and launch System Console again.
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.
khyam
Hello @RichardTanSY_Altera ,
I am able to launch and connect AFU through remote debug and I have done debugging of AFU using signal tap tool. Instead of signal tap, we can use the system console for FPGA memory debug using Avalon MM commands like master_write_32 and master_read_32.  I tried using the system console tool for FPGA memory debugging,  the claim command used for claiming the master service for operation(FPGA memory read/write).  I got the below error for claiming master service.
RichardTanSY_Altera
Hi @khyam
I am not sure what goes wrong... could you help to share your design (a simplified one .qar design file will do) that could duplicate this issue?
May I know what OS and which device that you are using?
Kindly help to provide the steps to duplicate the issue as well.
I will need to further investigate on this.
Richard Tan
RichardTanSY_Altera
Hi @khyam
Could you help to share your design (a simplified one .qar design file will do) that could duplicate this issue?
Richard Tan
RichardTanSY_Altera
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
