Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
458 Discussions
Weird log info while compile AOCX on quartus prime pro 19.1 for a10 board
zjinf
Hi inteler:
It appear weird log info while compile AOCX on quartus prime pro 19.1 for arria10 board
environment:
OS:centOS7.5
environment: Quartus prime pro 19.1.240
board: A10gx
when the Batchsize=8, it's OK, no problem, while batchsize=32(DSP utilization about 64%) or 47(DSP utilization about 99%), other logic element is below 50%, it shows the following info, Anybody can help me , or give me suggestion ??
Thanks in advance!
Compiler Command: aoc -v -board=a10gx -l ./bin/dot_product_efi.aoclib -I /home/iot/work_example/work2/meiyang/dotProduct/inc ./device/sim.cl -o ./bin/sim.aocx -report
terminate called after throwing an instance of 'std::bad_alloc'
 what(): std::bad_alloc
Stack dump:
0. Program arguments: /home/iot/intelFPGA_pro/19.1/hld/linux64/bin/../../llvm/bin/aocl-opt -march=fpga -O3 -board /home/iot/intelFPGA_pro/19.1/hld/board/a10_ref/hardware/a10gx/board_spec.xml -libfile /home/iot/work_example/work2/meiyang/int8_bs/bin/dot_product_efi.aoclib -dbg-info-enabled --soft-elementary-math=false -pass-remarks-output=pass-remarks.yaml sim.fpga.bc -o sim.kwgid.bc
1. Running pass 'Function Pass Manager' on module 'sim.fpga.bc'.
2. Running pass 'Mark the decision for loop pipelining' on function '@sim'
/home/iot/intelFPGA_pro/19.1/hld/llvm/bin/../lib/libLLVM-8svn.so(_ZN4llvm3sys15PrintStackTraceERNS_11raw_ostreamE+0x2a)[0x7f8087d3c1da]
/home/iot/intelFPGA_pro/19.1/hld/llvm/bin/../lib/libLLVM-8svn.so(_ZN4llvm3sys17RunSignalHandlersEv+0x4c)[0x7f8087d3a17c]
/home/iot/intelFPGA_pro/19.1/hld/llvm/bin/../lib/libLLVM-8svn.so(+0xc1c2cc)[0x7f8087d3a2cc]
/lib64/libpthread.so.0(+0xf6d0)[0x7f8086f116d0]
/lib64/libc.so.6(gsignal+0x37)[0x7f808586b277]
/lib64/libc.so.6(abort+0x148)[0x7f808586c968]
/home/iot/intelFPGA_pro/19.1/hld/llvm/bin/../lib/libstdc++.so.6(_ZN9__gnu_cxx27__verbose_terminate_handlerEv+0x15d)[0x7f80861ab40d]
/home/iot/intelFPGA_pro/19.1/hld/llvm/bin/../lib/libstdc++.so.6(+0x8f3e6)[0x7f80861a93e6]
/home/iot/intelFPGA_pro/19.1/hld/llvm/bin/../lib/libstdc++.so.6(+0x8f431)[0x7f80861a9431]
/home/iot/intelFPGA_pro/19.1/hld/llvm/bin/../lib/libstdc++.so.6(+0x8f648)[0x7f80861a9648]
/home/iot/intelFPGA_pro/19.1/hld/llvm/bin/../lib/libstdc++.so.6(+0x8fb5c)[0x7f80861a9b5c]
/home/iot/intelFPGA_pro/19.1/hld/llvm/bin/../lib/libLLVM-8svn.so(+0x25380fb)[0x7f80896560fb]
/home/iot/intelFPGA_pro/19.1/hld/llvm/bin/../lib/libLLVM-8svn.so(+0x253832a)[0x7f808965632a]
/home/iot/intelFPGA_pro/19.1/hld/llvm/bin/../lib/libLLVM-8svn.so(_ZN3acl6MemDep35LoopCarriedMemoryDependenceAnalysis13getDependenceEPN4llvm11InstructionES4_b+0x678)[0x7f808965a6f8]
/home/iot/intelFPGA_pro/19.1/hld/llvm/bin/../lib/libLLVM-8svn.so(_ZN3acl6MemDep35LoopCarriedMemoryDependenceAnalysis14getDependencesEPN4llvm11InstructionERNS2_11SmallPtrSetIS4_Lj2EEEb+0x27e)[0x7f808965d69e]
/home/iot/intelFPGA_pro/19.1/hld/llvm/bin/../lib/libLLVM-8svn.so(_ZN3acl17ArrayPrivAnalysis14isPrivatizableEjPSt6vectorIPN4llvm11InstructionESaIS4_EEPKNS2_4LoopE+0x114)[0x7f8089684a14]
/home/iot/intelFPGA_pro/19.1/hld/llvm/bin/../lib/libLLVM-8svn.so(_ZN3acl17ArrayPrivAnalysis24findAllPrivatizableLoopsEv+0x401)[0x7f808968a201]
/home/iot/intelFPGA_pro/19.1/hld/llvm/bin/../lib/libLLVM-8svn.so(_ZN3acl20LoopPipelineAnalysis19runPipelineAnalysisEPNS_17ArrayPrivAnalysisEPNS_37LoopCarriedDepsBeforePipelineAnalysisEPNS_14LocalMemConfigE+0x36)[0x7f8089799c06]
/home/iot/intelFPGA_pro/19.1/hld/llvm/bin/../lib/libLLVM-8svn.so(+0x20b6330)[0x7f80891d4330]
/home/iot/intelFPGA_pro/19.1/hld/llvm/bin/../lib/libLLVM-8svn.so(_ZN4llvm13FPPassManager13runOnFunctionERNS_8FunctionE+0x35e)[0x7f8087e7326e]
/home/iot/intelFPGA_pro/19.1/hld/llvm/bin/../lib/libLLVM-8svn.so(_ZN4llvm13FPPassManager11runOnModuleERNS_6ModuleE+0x44)[0x7f8087e73424]
/home/iot/intelFPGA_pro/19.1/hld/llvm/bin/../lib/libLLVM-8svn.so(_ZN4llvm6legacy15PassManagerImpl3runERNS_6ModuleE+0x3bc)[0x7f8087e741ec]
/home/iot/intelFPGA_pro/19.1/hld/linux64/bin/../../llvm/bin/aocl-opt(main+0x26c5)[0x558b03947b15]
/lib64/libc.so.6(__libc_start_main+0xf5)[0x7f8085857445]
/home/iot/intelFPGA_pro/19.1/hld/linux64/bin/../../llvm/bin/aocl-opt(+0x2a6bd)[0x558b039486bd]
HRZ
Valued Contributor III
Based on the "std::bad_alloc" error it looks like the compiler is running out of memory, possibly due to insufficient amount of memory installed on your compilation machine. If you have enough memory on the machine (32+ GB), this oculd then be a sign of some memory leak in the compiler that eventually fills the memory and crashes.
