Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
504 Discussions
What is the meaning of instance_id and how to use them in the 10Gbps Ethernet (10GbE) AFU design example on Intel PAC arria10gx
User1582192733150209
Hello Sir/Madam,
I am running the 10Gbps Ethernet
(10GbE) AFU design example on Intel PAC arria10gx, following the document 10Gbps
Ethernet Accelerator Functional Unit Design Example User Guide.
I am confused about several instance_id mentioned in the document.
For example ,on page 9, there is description about the instance_id as below
To configure the transceiver channel into 10G mode, write 10 to the following
sysfs entry:
$ sudo sh -c "echo 10 > /sys/class/fpga/intel-fpga-dev.<instance_id>\
/intel-fpga-fme.<instance_id>/intel-pac-hssi.<instance_id>.\
auto/hssi_mgmt/config"
<instance_id> represents the consecutive numbering of device, fme, and hssi
instances.
For example:
sudo sh -c "echo 10 > /sys/class/fpga/intel-fpga-dev.0\
/intel-fpga-fme.0/intel-pac-hssi.2.auto/hssi_mgmt/config"
For the instance_id relevant to intel-fpga-dev.<instance_id> and /intel-fpga-fme.<instance_id> , I know I can find them using below tcl
[root@fig01 bin]# fpgainfo fme
Board Management Controller, microconetroller FW version 26889
Last Power Down Cause: POK_CORE
Last Reset Cause: None
//****** FME ******//
Object Id                     : 0xED00001
PCIe s:b:d:f                  : 0000:D8:00:0
Device Id                     : 0x09C4
Socket Id                     : 0x00
Ports Num                     : 01
Bitstream Id                  : 0x123000200000185
Bitstream Version             : 0x562800030201
Pr Interface Id               : 69528db6-eb31-577a-8c36-68f9faa081f6
Board Management Controller, microcontroller FW version unavailable
Last Power Down Cause: unavailable
Last Reset Cause: unavailable (can't open)
Object Id                     : 0xED00000
PCIe s:b:d:f                  : 0000:3B:00:0
Device Id                     : 0x09C4
Socket Id                     : 0x00
Ports Num                     : 01
root@fig01 sw]# ls /sys/class/fpga
intel-fpga-dev.0  intel-fpga-dev.1
[root@fig01 sw]# ls /sys/class/fpga/intel-fpga-dev.0/
device  intel-fpga-fme.0  intel-fpga-port.0  power  subsystem  uevent
[root@fig01 sw]# ls /sys/class/fpga/intel-fpga-dev.0/intel-fpga-fme.0/
altr-asmip2.0.auto  bitstream_id        cache_size  dperf   emif_mgmt  fpga_manager           modalias   power  revision   subsystem     uevent
avmmi-bmc.2.auto    bitstream_metadata  dev         driver  errors     intel-pac-hssi.1.auto  ports_num  pr     socket_id  thermal_mgmt  version
[root@fig01 sw]# ls /sys/class/fpga/intel-fpga-dev.1/
device  intel-fpga-fme.1  intel-fpga-port.1  power  subsystem  uevent
[root@fig01 sw]# ls /sys/class/fpga/intel-fpga-dev.1/intel-fpga-fme.1/
altr-asmip2.3.auto  bitstream_id        cache_size  dperf   emif_mgmt  fpga_manager           modalias   power  revision   subsystem     uevent
avmmi-bmc.5.auto    bitstream_metadata  dev         driver  errors     intel-pac-hssi.4.auto  ports_num  pr     socket_id  thermal_mgmt  version
based on above information can I understand
for the card 0000:3B:00:0 , the 4 instance_id can be copied from above printing information intel-fpga-dev.0, intel-fpga-fme.0 , intel-pac-hssi.1.auto, intel-fpga-port.0
for the card 0000:d8:00:0 , the 4 instance_id can be copied from above printing information intel-fpga-dev.1, intel-fpga-fme.1 , intel-pac-hssi.4.auto, intel-fpga-port.1
does that mean
1,above intel-fpga-dev.0, intel-fpga-fme.0 , intel-pac-hssi.1.auto, intel-fpga-port.0  are fixed and do not need to change if the target card is  0000:3B:00:0 ?
2,intel-fpga-dev.1, intel-fpga-fme.1 , intel-pac-hssi.4.auto, intel-fpga-port.1 are fixed and do not need to change if the target card is  0000:d8:00:0?
The confused part is how to choose different channel since the example has 4*10G mode and has 4 10g channel (0,1,2,3) ?
I have only found  intel-pac-hssi.1.auto For card 0 , and , intel-pac-hssi.4.auto for card 1 from printing information.
Does that mean
1,intel-pac-hssi.1.auto intel-pac-hssi.2.auto , intel-pac-hssi.3.auto are not applicable for card 0?
2,intel-pac-hssi.0.auto intel-pac-hssi.2.auto , intel-pac-hssi.3.auto are not applicable for card 1?
If so, how can choose different channel(0,1,2,3) for the same card?
If those unsee parameters  are applicable , for example intel-pac-hssi.1.auto intel-pac-hssi.2.auto , intel-pac-hssi.3.auto are  applicable for card 0,
why I can not print them using above tcl, any other operation I can try please let me know.
Jim
correct some wrong typing as below
Does that mean
1,intel-pac-hssi.0.auto intel-pac-hssi.2.auto , intel-pac-hssi.3.auto are not applicable for card 0?
2,intel-pac-hssi.0. intel-pac-hssi.1.auto ,auto intel-pac-hssi.2.auto , intel-pac-hssi.3.auto are not applicable for card 1?
If those unsee parameters  are applicable , for example intel-pac-hssi.0.auto intel-pac-hssi.2.auto , intel-pac-hssi.3.auto are  applicable for card 0,
JohnT_Intel
The HSSI.? numbering is already fixed based and enumerated in the OPAE. For Intel Arria 10 PAC card will only have 1 HSSI block as it only have 1 QSFP interface. So in order to run each of the ethernet port, you will need to define which channel to run.
Example on sending 0x1000 packet onto each of the channel
./pac_hssi_e10 -b 00 -d 0a -f 0b --channel=0 --action=pkt_send
./pac_hssi_e10 -b 00 -d 0a -f 0b --channel=1 --action=pkt_send
./pac_hssi_e10 -b 00 -d 0a -f 0b --channel=2 --action=pkt_send
./pac_hssi_e10 -b 00 -d 0a -f 0b --channel=3 --action=pkt_send
