Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
aocl diagnose is not working
DeusMMJr
Hi, I'm trying to run my application in node 189 but I'm facing with some issues. One of them is aocl diagnose, It is not working to recognize s1_pac_sc bsp.
u28549@s001-n189:~$ aocl diagnose
/opt/intel/inteldevstack/d5005_ias_2_0_b339/opencl/opencl_bsp/linux64/libexec/diagnose: error while loading shared libraries: libintel_opae_mmd.so: cannot open shared object file: No such file or directory
Warning:
No devices attached for package:
As I can't permission to install this bsp I ask help with this.
FawazJ_Altera
It seems there is installation issue.
May I know which version are you using?
DeusMMJr
Intel(R) FPGA SDK for OpenCL(TM), 64-Bit Offline Compiler
Version 18.1.0 Build 222 Pro Edition
Copyright (C) 2018 Intel Corporation
DeusMMJr
Hi FJumaah, I solved the issue wih correct envirnoment setting included in init_env_nosudo script. Thanks
