Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
504 Discussions
cannot run GitHub samples on OneAPI FPGA emulator
wan11
I recently installed Ubuntu version 22.04 on my Mac2018. After the installation, I successfully installed the Intel® oneAPI Base Toolkit (Base Kit) along with the FPGA Support Package for the Intel oneAPI DPC++/C++ Compiler.
However, I cannot compile the program on the FPGA emulator although I tried the recommended configurations by following Intel's documentation. The error shows below.
wanyu@wanyu-MacBookPro15-1:~/Desktop/vector-add/build$ make fpga_emu
[ 50%] Linking CXX executable ../vector-add-usm.fpga_emu
OpenCL platform ID is empty
OpenCL platform name is empty
Failed to find any of these OpenCL platforms:
  Intel(R) FPGA Emulation Platform for OpenCL(TM)
  Intel(R) FPGA Emulation Platform for OpenCL(TM) (preview)
llvm-foreach:
icpx: error: fpga compiler command failed with exit code 14 (use -v to see invocation)
make[3]: *** [src/CMakeFiles/vector-add-usm.fpga_emu.dir/build.make:97: vector-add-usm.fpga_emu] Error 14
make[2]: *** [CMakeFiles/Makefile2:159: src/CMakeFiles/vector-add-usm.fpga_emu.dir/all] Error 2
make[1]: *** [CMakeFiles/Makefile2:192: src/CMakeFiles/fpga_emu.dir/rule] Error 2
make: *** [Makefile:163: fpga_emu] Error 2
Could you kindly provide guidance on the specific configurations or steps that need to be performed during the installation or post-installation to enable FPGA emulator support?
Thank you for your time and support. I look forward to your response.
Thank you,
Wanyu
Labels (2)
