Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
fpga_extension.hpp not found
Gao__Chao
I try to compile the cpu-fpga heterogeneous file, I came across this error, did anyone know it?
EBERLAZARE_I_Intel
This may seems that you are not in the correct directory when running compile. Can you re-check again if you have set the correct directory.
