Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
504 Discussions
hello world launch hang - intel a10 FPGA
ramgowda
I am trying to setup, compile run an hello world example. Below are the instructions I have followed, until launch kernel which just hangs there.
Please let me know if the setup instructions looks right any pointers to debug the kernel hang.
SETUP
source /local/ramachandra.utah/inteldevstack/init_env.sh
export INTELFPGAOCLSDKROOT=/local/ramachandra.utah/inteldevstack/intelFPGA_pro/hld/
export ALTERAOCLSDKROOT=/local/ramachandra.utah/inteldevstack/intelFPGA_pro/hld/
source /local/ramachandra.utah/inteldevstack/intelFPGA_pro/hld/init_opencl.sh
source /local/ramachandra.utah/inteldevstack/a10_gx_pac_ias_1_1_pv/opencl/opencl_bsp/linux64/libexec/setup_permissions.sh
export AOCL_BOARD_PACKAGE_ROOT=$INTELFPGAOCLSDKROOT/board/a10_ref
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/local/ramachandra.utah/inteldevstack/intelFPGA_pro/hld/board/a10_ref/linux64/lib
DRIVER install
aocl install
Do you want to install /local/ramachandra.utah/inteldevstack/intelFPGA_pro/hld//board/a10_ref? [y/n] y
 LD [M] /tmp/opencl_driver_f2SkG2/aclpci_a10_ref_drv.ko
[root@fpga002 ~]# lsmod | grep a10
aclpci_a10_ref_drv   41362 0
[root@fpga002 ~]# lsmod | grep fpga
intel_fpga_fme     52380 0
intel_fpga_afu     31735 0
fpga_mgr_mod      14693 1 intel_fpga_fme
intel_fpga_pci     26519 2 intel_fpga_afu,intel_fpga_fme
OPENCL
aocl diagnose
aocl program acl0 ./inteldevstack/a10_gx_pac_ias_1_1_pv/opencl/vector_add.aocx
aocl program acl1 ./inteldevstack/a10_gx_pac_ias_1_1_pv/opencl/vector_add.aocx
aocl diagnose // success
[root@fpga001 hello_world]# aoc -list-boards
Board list:
 a10gx
   Board Package: /local/ramachandra.utah/inteldevstack/intelFPGA_pro/hld/board/a10_ref
 a10gx_hostch
   Channels:   host_to_dev, dev_to_host
pac_a10
   Board Package: /local/ramachandra.utah/inteldevstack/a10_gx_pac_ias_1_1_pv/opencl/opencl_bsp
EMULATOR MODE (runs fine)
aoc -march=emulator -v -board=pac_a10 device/hello_world.cl -o bin/hello_world.aocx
module load intel/compiler/2019
make // compile host
env CL_CONTEXT_EMULATOR_DEVICE_INTELFPGA=1 bin/host // runs fine
BOARD COMPILATION
aoc -v -board=pac_a10 device/hello_world.cl -o bin/hello_world.aocx
BOARD RUN (hang)
[root@fpga001 hello_world]# ./bin/host
Querying platform for info:
CL_PLATFORM_NAME             = Intel(R) FPGA SDK for OpenCL(TM)
CL_PLATFORM_VENDOR            = Intel(R) Corporation
CL_PLATFORM_VERSION           = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 17.1.1
Querying device for info:
CL_DEVICE_NAME              = pac_a10 : PAC Arria 10 Platform (pac_a10_eb00001)
CL_DEVICE_VENDOR             = Intel Corp
CL_DEVICE_VENDOR_ID           = 4466
CL_DEVICE_VERSION            = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 17.1.1
CL_DRIVER_VERSION            = 17.1
CL_DEVICE_ADDRESS_BITS          = 64
CL_DEVICE_AVAILABLE           = true
CL_DEVICE_ENDIAN_LITTLE         = true
CL_DEVICE_GLOBAL_MEM_CACHE_SIZE     = 32768
CL_DEVICE_GLOBAL_MEM_CACHELINE_SIZE   = 0
CL_DEVICE_GLOBAL_MEM_SIZE        = 8589934592
CL_DEVICE_IMAGE_SUPPORT         = true
CL_DEVICE_LOCAL_MEM_SIZE         = 16384
CL_DEVICE_MAX_CLOCK_FREQUENCY      = 1000
CL_DEVICE_MAX_COMPUTE_UNITS       = 1
CL_DEVICE_MAX_CONSTANT_ARGS       = 8
CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE    = 2147483648
CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS    = 3
CL_DEVICE_MEM_BASE_ADDR_ALIGN      = 8192
CL_DEVICE_MIN_DATA_TYPE_ALIGN_SIZE    = 1024
CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR  = 4
CL_DEVICE_PREFERRED_VECTOR_WIDTH_SHORT  = 2
CL_DEVICE_PREFERRED_VECTOR_WIDTH_INT   = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_LONG  = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_FLOAT  = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_DOUBLE = 0
Command queue out of order?       = false
Command queue profiling enabled?     = true
Using AOCX: hello_world.aocx
Reprogramming device [0] with handle 1
Kernel initialization is complete.
Launching the kernel...
MuhammadAr_U_Intel
Hi, Can I know what version of OS are you using ? Looking at aocl diagnose, it seems you are using multiple devices. 1. Can you try aocl diagnose acl0 or acl1 and check if you see and READ/ WRITE transactions. 2. I notice you are missing the aocl flash command, please follow steps as mentioned in https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/opencl-sdk/aocl_getting_started.pdf Page 36, Programming the Flash Memory of an FPGA Let me know if this is helpful to you. Thanks, Arslan
ramgowda
Hi Arslan,
Thanks a lot for the response. I re did the setup referring the document from scratch.
But facing problems and errors when I do aocl flash, although the diagnose is successful.
Please review the below detailed instructions and let me know if I have did something wrong.
Check the interface ID
[root@fpga001 inteldevstack_1_1]# sudo fpgainfo fme
//****** FME ******//
Class Path       : /sys/class/fpga/intel-fpga-dev.0/intel-fpga-fme.0
Device Path      : /sys/devices/pci0000:85/0000:85:02.0/0000:86:00.0/fpga/intel-fpga-dev.0/intel-fpga-fme.0
Bus          : 0x86
Device         : 0x00
Function        : 0x00
Device Id       : 0x09C4
Fim Version      : 1.1.3
Ports Num       : 1
Socket Id       : 0
Bitstream Id      : 0x113000200000177
Bitstream Metadata   : 0x1805304
Pr Interface Id    : 9926ab6d-6c92-5a68-aabc-a7d84c545738
Object Id       : 247463936
Class Path       : /sys/class/fpga/intel-fpga-dev.1/intel-fpga-fme.1
Device Path      : /sys/devices/pci0000:d7/0000:d7:00.0/0000:d8:00.0/fpga/intel-fpga-dev.1/intel-fpga-fme.1
Bus          : 0xD8
Device         : 0x00
Function        : 0x00
Device Id       : 0x09C4
Fim Version      : 1.1.3
Ports Num       : 1
Socket Id       : 0
Object Id       : 247463937
Download and INSTALL the version for the above interface Id.
http://download.altera.com/akdlm/software/dcp/1.1/a10_gx_pac_ias_1_1_pv_dev_installer.tar.gz
./setup and install into /home/ramachandra.utah/inteldevstack_1_1/
Confirm if driver is loaded
[root@fpga001 inteldevstack_1_1]# sudo lsmod | grep fpga
intel_fpga_pac_hssi  18107 0
Setup environment
[root@fpga001 inteldevstack_1_1]# source /home/ramachandra.utah/inteldevstack_1_1/init_env.sh
export QUARTUS_HOME=/home/ramachandra.utah/inteldevstack_1_1/intelFPGA_pro/quartus
Adding $QUARTUS_HOME/bin to PATH
export OPAE_PLATFORM_ROOT=/home/ramachandra.utah/inteldevstack_1_1/a10_gx_pac_ias_1_1_pv
Adding $OPAE_PLATFORM_ROOT/bin to PATH
[root@fpga001 inteldevstack_1_1]# source /home/ramachandra.utah/inteldevstack_1_1/a10_gx_pac_ias_1_1_pv/opencl/opencl_bsp/linux64/libexec/setup_permissions.sh
This script handles device permissions and huge page table setup.
Please refer to DCP Quick Start User Guide for OPAE driver and SW installation
instructions.
/etc/security/limits.d/99-opae_memlock.conf is already setup.
setup huge pages. must be done after every reboot
sudo bash -c "echo 20 > /sys/kernel/mm/hugepages/hugepages-2048kB/nr_hugepages"
setup permissions for device. must be done after every reboot.
sudo chmod 666 /dev/intel-fpga-port.*
sudo chmod 666 /sys/class/fpga/intel-fpga-dev.*/intel-fpga-port.*/userclk_freqcmd
sudo chmod 666 /sys/class/fpga/intel-fpga-dev.*/intel-fpga-port.*/userclk_freqcntrcmd
sudo chmod 666 /sys/class/fpga/intel-fpga-dev.*/intel-fpga-port.*/errors/clear
sudo chmod 666 /dev/intel-fpga-fme.*
export AOCL_BOARD_PACKAGE_ROOT=/home/ramachandra.utah/inteldevstack_1_1/a10_gx_pac_ias_1_1_pv/opencl/opencl_bsp/
source /home/ramachandra.utah/inteldevstack_1_1/intelFPGA_pro/hld/init_opencl.sh
INTELFPGAOCLSDKROOT is set to /home/ramachandra.utah/intelFPGA_pro/18.1/hld. Using that.
Found a Quartus directory at /home/ramachandra.utah/intelFPGA_pro/18.1/quartus. Using that.
Adding /home/ramachandra.utah/intelFPGA_pro/18.1/hld/bin to PATH
Adding /home/ramachandra.utah/intelFPGA_pro/18.1/hld/host/linux64/lib to LD_LIBRARY_PATH
Adding /home/ramachandra.utah/intelFPGA_pro/18.1/hld/board/a10_ref/linux64/lib to LD_LIBRARY_PATH
Aocl install, diagnose and flash
[root@fpga001 inteldevstack_1_1]# aocl install
Do you want to install /home/ramachandra.utah/inteldevstack_1_1/a10_gx_pac_ias_1_1_pv/opencl/opencl_bsp? [y/n] y
aocl install: Adding the board package /home/ramachandra.utah/inteldevstack_1_1/a10_gx_pac_ias_1_1_pv/opencl/opencl_bsp to the list of installed pckages
aocl install: Setting up FCD
aocl install: Running install from /home/ramachandra.utah/inteldevstack_1_1/a10_gx_pac_ias_1_1_pv/opencl/opencl_bsp/linux64/libexec
WARNING: install not implemented. Please refer to DCP Quick Start User Guide
for installation instructions.
[root@fpga001 inteldevstack_1_1]# aocl diagnose
/home/ramachandra.utah/inteldevstack_1_1/a10_gx_pac_ias_1_1_pv/opencl/opencl_bsp/linux64/libexec/diagnose: error while loading shared libraries: libintel_opae_mmd.so: cannot open shared object file: No such file or directory
[root@fpga001 inteldevstack_1_1]# export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/home/ramachandra.utah/inteldevstack_1_1/a10_gx_pac_ias_1_1_pv/opencl/opencl_bsp/linux64/lib/
Device Name:
acl0
BSP Install Location:
Vendor: Intel Corp
Physical Dev Name  Status      Information
pac_a10_eb00001   Passed      PAC Arria 10 Platform (pac_a10_eb00001)
                   PCIe 216:00.0
                   FPGA temperature = 44 degrees C.
DIAGNOSTIC_PASSED
Device Name:
acl1
Vendor: Intel Corp
pac_a10_eb00000   Passed      PAC Arria 10 Platform (pac_a10_eb00000)
                   PCIe 134:00.0
DIAGNOSTIC_PASSED
aocl flash acl0 /home/ramachandra.utah/inteldevstack_1_1/a10_gx_pac_ias_1_1_pv/opencl/hello_world.aocx
aocl flash: Running flash from /home/ramachandra.utah/inteldevstack_1_1/a10_gx_pac_ias_1_1_pv/opencl/opencl_bsp/linux64/libexec
ERROR: flash not implemented. Please refer to DCP Quick Start User Guide for
aocl flash: Program failed.
MuhammadAr_U_Intel
Hi, Are you still facing issue or you are able to proceed ? Please try latest Acceleration stack version 1.2 and follow the instructions in quick starter guide first.. https://www.intel.com/content/www/us/en/programmable/documentation/iyu1522005567196.html Thanks, Arslan
