Application Acceleration With FPGAs
Programmable Acceleration Cards (PACs), DCP, FPGA AI Suite, Software Stack, and Reference Designs
504 Discussions
shift register cause computational results error????
zjinf
Hi inteler/alteraer
i refer p130~131 on https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/opencl-sdk/aocl-best-practices-guide.pdf write my code.
i found shift register will cause computational results error (1.0e-3f), that is integer parts and the first 2 bit of decimal also ok, no problem, but from the 3 bit , it will difference from PC ' results(for example : pc' results : 100.11234[FPGA without shift register also 100.11234], and fpga with shift register is 100.11341)
if i don't use shift register, the fpga's results is OK!
how can i fix the computational error!
thanks for your help!
zjinf
hi HRZ
Thanks for your explanation ! it seems like what you say above
HRZ
Valued Contributor III
There is no "computational error" to fix. You are changing the order of the floating-point computations using that optimization, which will result in minor differences in the output due to rounding differences. Floating-point computations are not associative. If your application does not allow re-ordering of floating-point operations, you should not use that optimization. If you are using Arria 10/Stratix 10, that optimization is not required for single-precision floating-point reduction and you can use single-cycle accumulation instead. Check Intel's guides for more info.
zjinf
hi HRZ
