Artificial Intelligence (AI)
696 Diskussionen
Quantizing ONNX Models using Intel® Neural Compressor
Tian_Feng
Mitarbeiter
2 0 12.7K
Authors: Bhargavi Karumanchi, Mengni Wang, Feng Tian, Haihao Shen, Saurabh Tangri
Guest Authors from Microsoft: Wenbing Li
ONNX (Open Neural Network Exchange)
ONNX is an open format to represent both deep learning and traditional models. ONNX is developed and supported by a community of partners such as Microsoft, Facebook, and AWS. At a high level, ONNX is designed to express machine learning models while offering interoperability across different frameworks. ONNXRuntime is the runtime library that can be used to maximize performance of Intel hardware for ONNX inference.
Quantization
Quantization is the replacement of floating-point arithmetic computations (FP32) with integer arithmetic (INT8). Using lower-precision data reduces memory bandwidth and accelerates performance.
8-bit computations (INT8) offer better performance compared to higher-precision computations (FP32) because they enable loading more data into a single processor instruction. Using lower-precision data requires less data movement, which reduces memory bandwidth.
Intel® Deep Learning Boost (Intel® DL Boost)
Intel® Deep Learning Boost (Intel® DL Boost) is a hardware acceleration feature available in second-generation Intel® Xeon® scalable processors to increase performance of deep learning workloads. Intel DL Boost Vector Neural Network Instructions (VNNI) delivers 3X performance improvement by combining three instructions into one for deep learning computations, thereby reducing memory bandwidth and maximizing compute efficiency and cache utilization.
Figure 1: Intel DL Boost VNNIFigure 1: Intel DL Boost VNNI
Quantization can introduce accuracy loss because fewer bits limit the precision and range of values. However, researchers have extensively demonstrated that weights and activations can be represented using 8-bit integers (INT8) without incurring significant loss in accuracy. Techniques such as post training quantization (PTQ) and quantization aware training (QAT) can recover loss in accuracy due to quantization. These techniques are available in an Intel supported open-source tool “Intel® Neural Compressor.”
Intel® Neural Compressor (formerly known as Intel® Low Precision Optimization Tool) is an open-source Python tool, which delivers unified interface to support multiple deep learning frameworks. It can be used to apply key model optimization techniques, such as quantization, pruning, knowledge distillation to compress models. This tool makes it easy to implement accuracy-driven tuning strategies to help user create highly optimized AI models. It has support for multiple weight pruning algorithms, which generate pruned models with predefined sparsity goals. This tool can also be used to apply knowledge distillation to distill the knowledge from the teacher model to a student model.
As shown in Figure 2, Intel® Neural Compressor is built on the top of frameworks and relies on framework interfaces to execute model training/inference/quantization/evaluation.
INC Infrastructure & Workflow
Figure 2: Intel® Neural Compressor InfrastructureFigure 2: Intel® Neural Compressor Infrastructure
In Figure 3, user provides an FP32 model and the targeted accuracy to the tool. Intel® Neural Compressor Quantization generates a tuning strategy based on the framework quantization capabilities, and model information. The tool picks a quantization scheme which produces the most optimized model for target accuracy.
Figure 3: Intel® Neural Compressor Quantization Working FlowFigure 3: Intel® Neural Compressor Quantization Working Flow
Quantizing ONNX Models Using Intel® Neural Compressor
In this tutorial, we will show step-by-step how to quantize ONNX models with Intel® Neural Compressor.
Intel® Neural Compressor takes FP32 model and YAML configuration file as two inputs. To construct the quantization process, users can either specify below settings via YAML or
Python APIs:
  1. Calibration Dataloader (Needed for static quantization)
  2. Evaluation Dataloader
  3. Evaluation Metric
Below is an example of how to enable Intel® Neural Compressor on MobileNet_v2 with built-in data loader, dataset, and metric
   1. Prepare quantization environment
# bash command
pip install onnx==1.7.0
pip install onnxruntime==1.6.0
pip install neural-compressor
2. Prepare a config file (YAML)
# conf.yaml
model:
  framework: onnxrt_qlinearops
quantization:
  calibration:
    sampling_size: 100
    dataloader:
      dataset:
        ImagenetRaw:
          data_path: /path/to/calibration/dataset
          image_list: /path/to/calibration/label
      transform:
        ResizeCropImagenet:
          height: 224
          width: 224
          mean_value: [0.485, 0.456, 0.406]
evaluation:
  accuracy:
    metric:
      topk: 1
    dataloader:
      dataset:
        ImagenetRaw:
          data_path: /path/to/evaluation/dataset
          image_list: /path/to/evaluation/label
      transform:
        ResizeCropImagenet:
          height: 224
          width: 224
3. Invoke the quantize() API
# main.py
import onnx
from neural_compressor.experimental import Quantization, common
model = onnx.load('./mobilenet_v2.onnx')
quantizer = Quantization('./conf.yaml')
quantize.model = common.Model(model)
q_model = quantizer()
q_model.save('./outputs/')
Results
Below is the table of quantization results by Intel® Neural Compressor. For the full validated model list, refer to this GitHub page.
Framework
Version
Model
Accuracy
Performance/ICX8380/1s4c10ins1bs/throughput(samples/sec)
INT8
FP32
Accuracy  Ratio[(INT8-FP32)/FP32]
INT8
FP32
Performance
Ratio[INT8/FP32]
onnxrt
1.8.0
alexnet
54.68%
54.80%
-0.22%
1195.53
626.44
1.91x
onnxrt
1.8.0
bert_base_mrpc_dynamic
84.56%
86.03%
-1.71%
341.47
144.42
2.36x
onnxrt
1.8.0
bert_base_mrpc_static
85.29%
86.03%
-0.86%
683.8
294.99
2.32x
onnxrt
1.8.0
bert_squad_model_zoo
80.43
80.67
-0.29%
106.91
59.97
1.78x
onnxrt
1.8.0
caffenet
56.22%
56.27%
-0.09%
1739.77
564.82
3.08x
onnxrt
1.8.0
distilbert_base_mrpc
84.56%
84.56%
0.00%
1626.07
554.5
2.93x
onnxrt
1.8.0
googlenet-12
67.73%
67.78%
-0.07%
928.78
717.07
1.30x
onnxrt
1.8.0
gpt2_lm_head_wikitext_model_zoo
32.07
28.99
10.61%
1.46
1.3
1.12x
onnxrt
1.8.0
mobilebert_mrpc
84.31%
86.27%
-2.27%
766.17
649.96
1.18x
onnxrt
1.8.0
mobilebert_squad_mlperf
89.84
90.02
-0.20%
91.06
81.05
1.12x
onnxrt
1.8.0
mobilenet_v2
65.19%
66.92%
-2.59%
2678.31
2807.88
0.95x
onnxrt
1.8.0
mobilenet_v3_mlperf
75.51%
75.75%
-0.32%
2960.51
1881.47
1.57x
onnxrt
1.8.0
resnet_v1_5_mlperf
76.07%
76.47%
-0.52%
884.23
497.15
1.78x
onnxrt
1.8.0
resnet50_v1_5
72%
72%
0%
855.49
493.39
1.73x
onnxrt
1.8.0
resnet50-v1-12
74.83%
74.97%
-0.19%
1008.72
520.8
1.94x
onnxrt
1.8.0
roberta_base_mrpc
88.24%
89.46%
-1.36%
724.68
284.01
2.55x
onnxrt
1.8.0
shufflenet-v2-12
66.15%
66.35%
-0.30%
4502.48
2721.01
1.65x
onnxrt
1.8.0
squeezenet
56.48%
56.85%
-0.65%
5008.01
3629.11
1.38x
onnxrt
1.8.0
ssd_mobilenet_v1
22.47%
23.10%
-2.73%
730.17
627.5
1.16x
onnxrt
1.8.0
ssd_mobilenet_v2
23.90%
24.68%
-3.16%
558.03
446.69
1.25x
onnxrt
1.8.0
vgg16
66.55%
66.68%
-0.19%
145.1
122.7
1.18x
onnxrt
1.8.0
vgg16_model_zoo
72.32%
72.38%
-0.08%
253.32
121.09
2.09x
onnxrt
1.8.0
zfnet
55.84%
55.97%
-0.23%
536.71
336.96
1.59x
Conclusion
By leveraging Intel® Neural Compressor, we achieved less than 1% accuracy loss and gained significant speedup in INT8 model performance compared to the FP32 model. We continue expanding the quantized model scope and contribute to ONNX model zoo.
Please send your pull requests for review if you have improvements to Intel® Neural Compressor. If you have any suggestions or questions, please contact inc.maintainers@intel.com.
Notices & Disclaimers
Performance varies by use, configuration and other factors. Learn more at www.Intel.com/PerformanceIndex.
Performance results are based on testing as of dates shown in configurations and may not reflect all publicly available updates. See backup for configuration details. No product or component can be absolutely secure.
