Artificial Intelligence (AI)
826 Discussions
VNDF importance sampling for an isotropic Smith-GGX distribution
AnisBenyoub
Importance sampling is a key ingredient of path tracing: the faster the sampling, the faster the rendering.
In this blog post, you will find an implementation for importance sampling a VNDF (GGX-Smith) isotropic distribution that is 15% faster than the current state of the art and doesn’t require building a local basis.
Here is the HLSL implementation:
float3 sample_vndf_isotropic(float2 u, float3 wi, float alpha, float3 n)
    // decompose the floattor in parallel and perpendicular components
    float3 wi_z = -n * dot(wi, n);
    float3 wi_xy = wi + wi_z;
    // warp to the hemisphere configuration
    float3 wiStd = -normalize(alpha * wi_xy + wi_z);
    // sample a spherical cap in (-wiStd.z, 1]
    float wiStd_z = dot(wiStd, n);
    float z = 1.0 - u.y * (1.0 + wiStd_z);
    float sinTheta = sqrt(saturate(1.0f - z * z));
    float phi = TWO_PI * u.x - PI;
    float x = sinTheta * cos(phi);
    float y = sinTheta * sin(phi);
    float3 cStd = float3(x, y, z);
    // reflect sample to align with normal
    float3 up = float3(0, 0, 1.000001); // Used for the singularity
    float3 wr = n + up;
    float3 c = dot(wr, cStd) * wr / wr.z - cStd;
    // compute halfway direction as standard normal
    float3 wmStd = c + wiStd;
    float3 wmStd_z = n * dot(n, wmStd);
    float3 wmStd_xy = wmStd_z - wmStd;
    // return final normal
    return normalize(alpha * wmStd_xy + wmStd_z);
Where wi is the view vector in world space, n the normal in world space, alpha the isotropic roughness and u a pair of random values (usually they are stratified and dithered).
Here is the GLSL implementation:
vec3 SampleVndf_GGX(vec2 u, vec3 wi, float alpha, vec3 n)
    // decompose the vector in parallel and perpendicular components
    vec3 wi_z = n * dot(wi, n);
    vec3 wi_xy = wi - wi_z;
    vec3 wiStd = normalize(wi_z - alpha * wi_xy);
    float phi = (2.0f * u.x - 1.0f) * M_PI;
    float z = (1.0f - u.y) * (1.0f + wiStd_z) - wiStd_z;
    float sinTheta = sqrt(clamp(1.0f - z * z, 0.0f, 1.0f));
    vec3 cStd = vec3(x, y, z);
    vec3 up = vec3(0, 0, 1);
    vec3 wr = n + up;
    vec3 c = dot(wr, cStd) * wr / wr.z - cStd;
    vec3 wmStd = c + wiStd;
    vec3 wmStd_z = n * dot(n, wmStd);
    vec3 wmStd_xy = wmStd_z - wmStd;
    // warp back to the ellipsoid configuration
    vec3 wm = normalize(wmStd_z + alpha * wmStd_xy);
    return wm;
Note that our method is an improvement of our publication from last year (see here: https://www.intel.com/content/www/us/en/developer/articles/technical/sampling-visible-ggx-normals.html).
Tags (2)
