Developing Games on Intel Graphics
If you are gaming on graphics integrated in your Intel Processor, this is the place for you! Find answers to your questions or post your issues with PC games
492 Discussions
13900 770 gpu raptor lake and opengl
westj
It seems that since the 12th gen and 13th gen gpu are having issues working properly. Linux 22.04 os and opengl are causing artifact issues and flickering. Not for sure what exactly is causing this but have no issues until I update to Mesa 23. So is there a driver that needs to be updated or a fix for this issue.
karen_intel
Hey @westj ty for reaching out
In order to investigate what needs to be done to fix the issue you're seeing, can you please share an evidence of what the artifacts/flickering look like?
We'd also need the OpenGl example to try to repro the same behavior on a machine similar to yours
Please include your system's SSU and the package that was working well prior to MESA 23 to have the full info and test.
Thanks! Looking forward to hear from you
Karen
westj
I had to upgrade to a different package because the shade was off a bit. But if I take the previous version and put it in 10900 it works fine and no shade issues. When I upgraded to new mesa, then everything broke flickering and artifacts. Both the 13900 and the 10900 intel chips. I have tried different repos, different kernels, and even modifying code.
Also the error for the ssu
ssu_3.0.0.2_tar.gz
This product is not supported on this operating system.
Would you like to try to scan? (y/n)
y
ssu.sh: 741: [[: not found
ssu.sh: 743: [[: not found
ssu.sh: 745: [[: not found
ssu.sh: 748: [[: not found
ssu.sh: 817: Bad substitution
ssu.sh: 867: Syntax error: Bad for loop variable
Previous set up in my gen 10900
uname -a
Linux sp 5.6.0-1028-oem #28-Ubuntu SMP Tue Sep 8 13:34:39 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
glxinfo -B
name of display: :0.0
display: :0 screen: 0
direct rendering: Yes
Extended renderer info (GLX_MESA_query_renderer):
Vendor: Intel Open Source Technology Center (0x8086)
Device: Mesa DRI Intel(R) UHD Graphics 630 (CML GT2) (0x9bc5)
Version: 20.0.8
Accelerated: yes
Video memory: 3072MB
Unified memory: yes
Preferred profile: core (0x1)
Max core profile version: 4.6
Max compat profile version: 3.0
Max GLES1 profile version: 1.1
Max GLES[23] profile version: 3.2
OpenGL vendor string: Intel Open Source Technology Center
OpenGL renderer string: Mesa DRI Intel(R) UHD Graphics 630 (CML GT2)
OpenGL core profile version string: 4.6 (Core Profile) Mesa 20.0.8
OpenGL core profile shading language version string: 4.60
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL version string: 3.0 Mesa 20.0.8
OpenGL shading language version string: 1.30
OpenGL context flags: (none)
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 20.0.8
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
Update version
uname -a
Linux sp 5.17.0-1035-oem #36-Ubuntu SMP PREEMPT Fri Jul 14 13:27:38 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
sudo glxinfo -B
Vendor: Intel (0x8086)
Device: Mesa Intel(R) Graphics (RPL-S) (0xa780)
Version: 23.3.3
Accelerated: yes
Video memory: 15694MB
Unified memory: yes
Max compat profile version: 4.6
OpenGL renderer string: Mesa Intel(R) Graphics (RPL-S)
OpenGL core profile version string: 4.6 (Core Profile) Mesa 23.3.3 - kisak-mesa PPA
OpenGL version string: 4.6 (Compatibility Profile) Mesa 23.3.3 - kisak-mesa PPA
OpenGL shading language version string: 4.60
OpenGL profile mask: compatibility profile
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 23.3.3 - kisak-mesa PPA
westj
Okay so on creating the same issues based on code maybe a little bit more difficult. I know where the flickering cause the issue but cannot figure out why. If you need the fill code I can provide it but the program is huge.
d->framerate_duration = time_duration(microseconds(1000000 / framerate));
If this is change to 250000 the flickering stops, which makes no sense.
d->framerate_duration = time_duration(microseconds(250000 / framerate));
Artifact is very visible.
glTexImage2D(GL_TEXTURE_2D, 0, GL_RGB,
texture_width, texture_height,
0, GL_RGBA, GL_UNSIGNED_BYTE, read_address);
I can partially remove by using GL_RGB32F, most of the artifact will go away but it will come back when the video has move movement.
glTexImage2D(GL_TEXTURE_2D, 0, GL_RGB32F,
karen_intel
Hey @westj  thank you for replying so quickly!
And thank you for the evidence too, it looks kinda ugly
Can you create a small project for us which will focus only on making the calls to reproduce the artifacts?
We definitely don't need access to the whole code.
I'm asking for it because if I'm able to repro I need to pass the same project to the development team so they have an easy way to root cause the issue.
Keep me posted!
Karen
westj
karen_intel
Hi @westj can you please share the project we requested to reproduce the issue?
If there's no response in the upcoming days we will have to close this thread due to inactivity
Karen
westj
I do apologize with the delay  I am also working with mesa for the opengl issues with iris. Trying to use apitrace but the errors are weird from what I gather. But I did notice another error that I am waiting for a response on. I can trying to package my program together and send but there will be a few things that they may need to add to run it.
libEGL warning: failed to get driver name for fd -1
libEGL warning: MESA-LOADER: failed to retrieve device information
karen_intel
Hey @westj welcome back!
No problem. We can wait We just don't want to leave cases without activity or solution open
I'll be waiting for your piece of code
Karen
westj
Everything should be here that you need to run the files, the tar.xz has the binary files, screenshots, and simple instructions. If anyone has any questions don't hesitate to reach out. All of this can be ran on any machine 10th gen it will work. But 13th gen is the issue target, running with linux 22.04 current kernel for my machine is  6.5.0-1003-oem. But from my finding working with mesa using apitrace, the issue come down to egl and iris driver not working.
karen_intel
@westj Okay, thanks a lot
We will proceed to debug this case. Once we're able to confirm the issue will get back to you with a report number
Otherwise, if we have questions I will contact you again. Have a great day
Karen
westj
karen_intel
Hii @westj we're waiting on feedback from the driver team for updates on OpenGL
Next week I'll get back to you in case I have anything I want you to test on your end
Karen
