Developing Games on Intel Graphics
If you are gaming on graphics integrated in your Intel Processor, this is the place for you! Find answers to your questions or post your issues with PC games
545 Discussions
Blue screen when using CUI SDK to Send IGFX_I2C_AUX_WRITE Data with Intel HD Graphics 520(21.20.16.4860,)
Ni__Wendy
System Information:
System Used: Dell xps13 9350
CPU SKU: Intel(R) Core(TM) i3-6100U
GPU SKU: Intel (R) HD Graphics 520 (21.20.16.4860)
Graphics Driver Version: 21.20.16.4860
Operating System: Windows 7 32bit
when use CUI SDK SetDeviceData function to Send I2C Over AUX Signal through type-C Port. The computer appears blue screen....
e,g,
ZeroMemory(&InData, sizeof(IGFX_AUX_INFO));
InData.dwDeviceUID = m_ulMonitorUid;
InData.dwOpType = IGFX_I2C_AUX_WRITE;
InData.dwAddress = nAddress;
InData.Data[0] = ucSubAddress;
InData.dwSize = (nWriteDataLength + 1);
for(int i = 0 ; i < nWriteDataLength; i++)
InData.Data[i + 1] = pBuffer;
HRESULT hr = m_pCUIExternal8->SetDeviceData(IGFX_GET_SET_AUX_INFO_GUID, sizeof(InData), (BYTE*)&InData, &dwError);
Michael_C_Intel2
Is it happening with the latest driver release?
If so then I need the following template filled out so an issue con be properly reported. Also if you have a binary sample the shows the issue it would be helpful.
System Setup Information:
System Used: (Manufacturer/Model)
CPU SKU: (i3, i5, Pentium, Celeron, etc.)
GPU SKU: (HD4400, HD5100, etc.)
Processor Line: (Y-Series, U-Series, etc.)
System BIOS Version:
CMOS settings:
GOP/VBIOS Version:
Operating System:
OS Version:
API:
Occurs on non-Intel GPUs?:
Steps to Reproduce:
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
Expected Results:
Actual Results:
Additional Information:
