I play Microsoft Flight Simulator and Microsoft Flight Simulator 2024. For both games, I use an addon called GSX Pro, which gives me pushback functionality for aircraft and other things.
This addon connects to the simulator through an external scripting engine program called 'couatl64' with different versions for each simulator, but which have the same principle. This program is having problems on my PC.
Recently, the developer released an update to this program, and after that, I started having problems with it. Basically, when I try to use it within the game, the program crashes and restarts automatically, only to crash again and so on, continuing this cycle of crashes and restarts indefinitely. It's important to note that the crashes are limited to the addon only and do not affect the game itself, which continues to work normally.
The program log gives no clues as to what is causing this. So I checked the Windows Event Viewer and it shows that the faulty module that is possibly causing these crashes is igd12um64xeh.dll
Faulting application name: couatl64_MSFS2024.exe, version: 5.0.0.5577, timestamp: 0x678522aa
Faulting module name: igd12um64xeh.dll, version: 32.0.101.6557, timestamp: 0x679934e9
Exception code: 0xc0000409
Fault offset: 0x0000000000ed6058
Faulting process ID: 0x22C0
Faulting application start time: 0x1DB799A11F33305
Faulting application path: C:\Program Files (x86)\Addon Manager\couatl64\couatl64_MSFS2024.exe
Faulting module path: C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_2133089e1a0733e8\igd12um64xeh.dll
Report ID: 09d14079-1250-4e93-9559-b2f6d3dc0a12
Faulting package full name:
Faulting package relative application ID:
I did some research and found that this dll is possibly related to the Intel Graphics Driver. I brought my findings to the addon developer and he has no idea what is causing this. It just raises my same suspicion that some modification of the program made it somehow incompatible with Intel Arc cards.
I know it will be very difficult to investigate a problem with a third-party add-on for a game rather than the game itself, but I am willing to help you with whatever is necessary.
My card is an Intel Arc A770 16GB and I'm using the latest drivers.
update on this?
I have the same issue with my sparkle B580 graphics card and the GSX add on for both Microsoft Flight Simulator 2020 and 2024. No issues with GSX on my pc with the Nvidia MSI 3060 graphics card.
I am also experiencing this error using GSX.
Windows 11
AMD Ryzen 7 5700X
Intel Arc A770 16 GB (Intel Graphics Driver 32.0.101.6972)
____________________________________________________________________________________________
Faulting application name: couatl64_MSFS2024.exe, version: 5.0.0.5984, time stamp: 0x687a8d8d
Faulting module name: igd12um64xeh.dll, version: 32.0.101.6972, time stamp: 0x687ab8fc
Fault offset: 0x0000000000f27578
Faulting process id: 0x3394
Faulting application start time: 0x1DC031350862350
Faulting module path: C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_204ba96c6f0b3e1c\igd12um64xeh.dll
Report Id: 45e57eab-03a8-4d9f-989d-e8ac50e25c62
Faulting package-relative application ID:
Fault bucket , type 0
Event Name: BEX64
Response: Not available
Cab Id: 0
Problem signature:
P1: couatl64_MSFS2024.exe
P2: 5.0.0.5984
P3: 687a8d8d
P4: igd12um64xeh.dll
P5: 32.0.101.6972
P6: 687ab8fc
P7: 0000000000f27578
P8: c0000409
P9: 0000000000000005
P10:
Event Name: LiveKernelEvent
Cab Id: 0
Problem signature:
P1: 193
P2: 80e
P3: ffffbc0e80b9e080
P4: ffffd084949748a0
P5: 0
P6: 10_0_26100
P7: 0_0
P8: 256_1
P9:
P10:
Event Name: BlueScreen
Cab Id: 0
Problem signature:
P1: 101
P2: c
P3: 0
P4: ffffc38186462180
P5: e
P6: 10_0_26100
P7: 0_0
P8: 256_1
P9:
P10:
Fault bucket 2124014821544153323, type 5
Event Name: BEX64
Cab Id: 0
Problem signature:
P2: 5.0.0.5984
P3: 687a8d8d
P5: 32.0.101.6972
P6: 687ab8fc
P8: c0000409
P10:
