I've stumbled on a driver bug, where when using glShadeModel(GL_FLAT) the triangle color is not always taken from the last vertex as it should.
Here's how this looks with the Intel card:
... and the same thing with ATI and NVidia cards:
Executable (requires glut32.dll):
Source:
The same thing happens with normals and when using VBO.
Tested on an Asus eeepc 1000h, Windows XP, with drivers version 6.14.10.4906(the latest from Asus) and 6.14.10.4926
BTW, the VBOs on 4926 are very unstable. 4906 has no VBOs
Source:
[cpp]#include "stdafx.h"
#include
void display(void)
int colors[7] = { 0xff0000,0x00ff00,0x0000ff, 0xff00ff,0xff00ff,0xff00ff,0xff00ff };
int indexes[18] = { 1,2,0, 2,3,0, 0,4,1, 4,5,1, 1,5,2, 5,6,2 };
float verts[21] = { 0,-2,0, 0,0,0, -1,1,0, -1,-1,0, 1,-1,0, 1,1,0, 0,2,0 };
glClear( GL_COLOR_BUFFER_BIT );
glEnableClientState( GL_VERTEX_ARRAY );
glEnableClientState( GL_COLOR_ARRAY );
glColorPointer( 4, GL_UNSIGNED_BYTE, 0, colors );
glVertexPointer( 3, GL_FLOAT, 0, verts );
glDrawElements( GL_TRIANGLES, 18, GL_UNSIGNED_INT, indexes );
glDisableClientState( GL_VERTEX_ARRAY );
glDisableClientState( GL_COLOR_ARRAY );
glFlush();
void init(void)
glShadeModel( GL_FLAT );
glMatrixMode( GL_PROJECTION );
glLoadIdentity();
glOrtho( -2, 2, -3, 3, -1, 1 );
int _tmain( int argc, char** argv )
glutInit( &argc, argv );
glutInitDisplayMode( GLUT_SINGLE | GLUT_RGB );
glutInitWindowSize( 250, 250 );
glutInitWindowPosition( 100, 100 );
glutCreateWindow( "Fix me!!!" );
init();
glutDisplayFunc( display );
glutMainLoop();
return 0;
}[/cpp]
Quoting - thegeleto
Source:
Source:
#include
void display(void)
glFlush();
void init(void)
glLoadIdentity();
init();
glutMainLoop();
return 0;
}[/cpp]
I will open a driver bug for this. Stay tuned.
Any news for this?
Any news for this?
Unfortunately, GMA950 is not actively supported anymore. I will check with the team to see if this resolved previously.
-Ganesh
