Developing Games on Intel Graphics
If you are gaming on graphics integrated in your Intel Processor, this is the place for you! Find answers to your questions or post your issues with PC games
HD Graphics sustained max frequency
Murali_M_
Hi
I would like to know if the HD Graphics 4600 and Iris 5xxx series can be sustained at maximum clock frequency of 1GHz and above.
What are the conditions under which the Graphics stays at max clock?
Assume that we would want to use the QuickSync video as well as other Video processing functions along with Graphics cores (OpenCL GPU code running on the cores), in such a scenario what would be the sustained clock frequency. Will it be the minimum like 200MHz or can it be sustained at higher clocks like 1GHz.
Murali
Michael_C_Intel2
Hi Murali,
Due to varying power characteristics, some parts with Intel Turbo Boost Technology 2.0 may not achieve maximum turbo frequencies when running heavy workloads and using multiple cores concurrently.
Availability and frequency upside of Intel Turbo Boost Technology 2.0 state depends upon a number of factors including, but not limited to the following:
  • Type of workload
  • Number of active cores
  • Estimated current consumption
  • Estimated power consumption
  • Processor temperature
When the processor is operating below these limits and the user's workload demands additional performance, the processor frequency will dynamically increase until the upper limit of frequency is reached. Intel Turbo Boost Technology 2.0 has multiple algorithms operating in parallel to manage current, power, and temperature to maximize frequency and energy efficiency. Note: Intel Turbo Boost Technology 2.0 allows the processor to operate at a power level that is higher than its TDP configuration and data sheet specified power for short durations to maximize performance.
Also keep in mind that with not all 4th Gen Intel Core Processors with HD4600 graphics will have a max speed of 1GHz, some may be 800MHz. So you may want to confirm the specifications of your processor.
I hope this helps.
