- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
This post is a follow up from this comment to explain a bit more our case.
I'm posting in this forum but I could move this elsewhere if it's more appropriate.
We are a medical imaging software company providing a web viewer, XploreViewWeb, for medical imaging especially for CT scan and MRI images which needs to be viewed as 3D volume.
To do so we're using a library named cornerstonejs which is widely used worldwide by most web viewer.
The problem comes from the JS function `gl.textSubImage3D()` which is translated later by all major browsers (from the angle project) to `DeviceContext::UpdateSubresource()` on Windows since D3D11 is being used by default.
We tried to workaround this but there isn't much you can do on JS.
We could use `gl.texImage3D()` but that's not really practical, requires to download all images before being able to render, need to pre-build the volume in RAM before sending to GPU which is costy, and would require to detect GPU used to apply the workaround which is not really something you can do on web sandbox.
And really we're building a volume from slice data which is exactly the purpose of `gl.textSubImage3D()`.
Another workaround is to change an advanced property on some browsers to not use D3D11. But this is not viable for a large scale of non-tech users, let aside security politics preventing changes of such settings.
About the number of affected user, it's hard to say but it is huge, let's see why :
- from our end we got hundred of reports and we currently have 20K+ physicians and 1M+ patients using our viewer. We don't know precisely how many are on intel GPU but, from the reports, we know for sure it's not marginal.
- Cornerstone has several posts about this (here and here for example) and OHIF (which is the open source viewer counter part) also has posts about it. Again we don't know precisely the numbers but those projects are widely used worldwide.
- a new french project named DRIMBox is being developed to share medical imaging across the country for all french physicians and patients. During test sessions we could see all web viewers were affected not just ours. Here we're on a scale of millions of total users, which should still translate to some millions of affected users using Intel GPU.
- problem being indirectly part of the Angle project (there is also an issue on their forum about it.) any web application using `gl.textSubImage3D()` is affected since Angle is the backend used by all major web browsers.
You can find a very simple and minimal reproduction here .
Or using the OHIF Viewer, changing the layout (on top) to MPR will produce the memory leak.
Link copiado
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi @pgranjal thanks a lot for the information and welcome to our dev support forum
I was able to repro the memory leak in Edge and Chrome.
Allow me to do some more triage and I'll report back tomorrow, stay tuned
Karen
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello @karen_intel,
Were you able to progress on this ?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi @pgranjal YES! Sorry for the delay , small update
We've been doing some triage and we're also creating an internal report for the driver team
I will share the ID as soon as possible, thank you for your patience
Karen
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
@pgranjal here's the internal report number for the memory leak you have reported: 14025017247
I've made sure to include the impact you included in the description. If we need anything in particular I'll let you know here.
We are also creating an article to inform the community we're already aware of this behavior. I'll post the URL after it has been created.
Thank you for your help.
Karen
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello @karen_intel,
Can we track the progress of your internal report somewhere ? I was not able to find what to do with that number.
Also the article is a great idea, so we can make it a reference, were you able to post it already ?
Thanks for you help
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello @karen_intel ,
Regarding the recent changes on this forum stated here
Should we move this to the IGCIT on github ?
Or maybe elsewhere as all those seems to be about video games and this issue is totally unrelated to games or games development.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi @pgranjal thank you for reaching out
This forum doesn't have active support anymore.
About this issue, we've done several testing and as the issue is only happening on systems that are 11th Gen or older, the support for this type of hardware has moved to legacy.
I haven't had any luck reproducing it on newest systems, meaning I cannot push further with the current hw support.
If you get to reproduce it on newest generations, please submit a new report through IGCIT and I'll be glad to create a new report for you and follow it along with you
Karen
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
That's great! I'll make sure to create a new report as soon as possible
Please tag me in the comments
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello Karen.
If you're in charge here, I need your help.
Since none of my threads have received an adequate response.
No solutions have been provided.
Thank you
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
