Developing Games on Intel Graphics
If you are gaming on graphics integrated in your Intel Processor, this is the place for you! Find answers to your questions or post your issues with PC games
Replacing expression e with (false ? ... : e) causes dramatic change in rendering
Alastair_D_1
I have a fragment shader for which changing:
            color = vec3(1.0, 0.1, 0.1) * diffuse;
to:
            color = vec3(1.0, 0.1, 0.1) * (false ? mix(targetDepth, time, false) : diffuse);
causes a dramatic change in what is rendered.  However, I would have expected this change to have no effect since (false ? ... : diffuse) should evaluate to diffuse.
To reproduce the issue, rename geexlab.txt (attached) to geexlab.xml and load it in GeeXLab.  The file as is should render something similar to good.png (attached).  This is the expected behaviour of the shader, which originates from here:
http://glslsandbox.com/e#29059
Changing line 99 of geexlab.xml to line 101 should render something similar to bad.png (attached), which is dramatically different.
I am using Iris Graphics 6100, driver version 20.19.15.4352, under Windows 10.
Are others able to reproduce this issue?
Ally
Michael_C_Intel2
Hi Alastair,
I got the ticket filed and let the team know.
-Michael
Michael_C_Intel2
Hi Alastair,
This issue is fixed and should be available in the next driver release.
-Michael
Alastair_D_1
Great stuff, thanks Michael.
Ally
Stefan3D
Driver v4463 is out.
Looks like you forgot to commit the fixes to the Broadwell branch?
Michael_C_Intel2
4463 was released 4/29 before we had a fix for this issue.
Stefan3D
Re-checked with v4474, issue persists
Islam_A_
Hello Michael,,
this is great stuff...thanks Michael.
Stefan3D
Issue still persists with 20.19.15.4501 (8-11-2016)
