Developing Games on Intel Graphics
If you are gaming on graphics integrated in your Intel Processor, this is the place for you! Find answers to your questions or post your issues with PC games
This forum offers only peer-to-peer support. Thank you!
Learn more about Developing Games on Intel Graphics
551 Discussions
Replacing p with (p * vec3(1.0) leads to malformed image
Alastair_D_1
I attach a .zip containing shader.frag (among other files), and two .png images; good.png and bad.png.
shader.frag is taken from http://glslsandbox.com/ (some acks below for the original source) and is meant to produce an image looking like good.png.
If the expression "p" at line 27 is replaced with "(p * vec3(1.0))", the shader produces an image looking like bad.png.
As with my previous report, I believe this is due to a compiler bug, since this expression change should likely have no effect (I would expect it to be optimized away).
My platform:
- Windows 10
- Intel(R) HD Graphics 520
- Driver version 20.19.15.4326
The attached archive contains the necessary files to reproduce this problem, with instructions on how to do so in README.txt.
Acks for the original shader:
// PlayingMarble.glsl
// original code from https://www.shadertoy.com/view/MtX3Ws
// simplified edit: Robert 25.11.2015
// see also https://www.shadertoy.com/view/Mlj3zWprecision mediump float;
// modified color calculation by I.G.P.
Michael_C_Intel2
Got it filed, and I will update you when we know something.
-Michael
Michael_C_Intel2
Hi Alastair,
We found the root cause and have a fix. It should be in the next driver release.
-Michael
Alastair_D_1
Great, thanks for confirming.
