Developing Games on Intel Graphics
If you are gaming on graphics integrated in your Intel Processor, this is the place for you! Find answers to your questions or post your issues with PC games
550 Discussions
Unstable FramteTime in Battlefield 6
ZahinfanofARC
Hey,
First of all, thank you very much for the fast update regarding the A-series Issue in BF6. Well done, Intel team. Now I have encountered maybe not an issue, but you guys should check it out.
While playing BF6, I saw that the frame time is very unstable and there are a lot of spikes in the frame time. This was tested on the latest driver, which was released today, and everything is up to date. My system Specs are:
Cpu: 5700x
GPU: Arc A770
Ram: 16 GB
My FPS was stable around 68-75 fps, which was the locked FPS, and there is no issue. But due to the unstable Frame time, the game feels laggy, and the frame time spikes to high levels sometimes in the game. Talking about the 1% low, it was around 40-50 FPS. I will be sending Screenshots so that you can check them properly. Another issue I am facing is, sometimes the game randomly crashes without any error. So I am not sure if it's a driver-related or system-related issue of mine. So I request you guys to check that also. But now I think you should deal with the frame time.
Oh, another thing is When Using Xe Frame gen, it doesn't improve the FPS at all, but it makes the game laggy laggy, and the frame times spike to the highest. Unfortunately, there is no screenshot of that, but the frame gen doesn't work at all, and the fps remains constant and the same. So I think this is also an issue you should check. And that's it. Hoping to hear from you guys for an update
CrilAR
What i am very aware of is, the Intel drivers are not really stable at this moment. The Fps drops do happen a lot and the usual locked fps might be around 40-50 on the lower cpu models even tho the cpu usage is around %50's. I believe if they can fix this and make the graphics cards stable (Without lags,stable fps and normal amounts of locked fps for every pc) again most games would be playable again. But this is not my profession, just suggesting at this point.
Ethan125
Thank you for the quick resolution of the A-series issue in BF6 — great job on that update.
I wanted to report some new concerns I’ve noticed while playing BF6 with the latest driver (released today). My system specs are:
  • CPU: Ryzen 7 5700X
  • GPU: Intel Arc A770
  • RAM: 16 GB
1. Frame Time Instability
While FPS remains stable between 68–75 (locked), frame time is very unstable with frequent spikes, making the game feel laggy. My 1% lows are around 40–50 FPS. I’ll be sending screenshots so you can review them in detail.
2. Random Game Crashes
Occasionally, the game crashes without any error message. I’m unsure if this is related to the driver or my system configuration, but thought it was worth mentioning.
3. Xe Frame Generation Issue
When using Xe Frame Gen, FPS does not improve and remains constant, but game smoothness worsens significantly — frame time spikes are more severe, and the gameplay feels noticeably laggy. Unfortunately, I don’t have screenshots for this scenario, but it’s very repeatable.
I’d appreciate it if your team could look into these frame time issues first, as they affect the gameplay experience the most.
