I am trying to learn DL Workbench. but as I select any model to import, from Model Zoo or Hugging Face, I got
" Unable to execute Model Download status API"
Can you help me with this issue?
Thank you for your help!
- Tags:
- import model
once you created an account, make sure you've done step 2 (Verify your access to JupyterLab env)
Access the DLworkbench from Jupyterlab (this will redirect you to the Workbench site)
I managed to import the model if I did it this way
Cordially,
Iffa
Could you clarify:
1. Are you using a custom model? or any changes that you did to the model?
2. Cross-check whether the steps to upload the model that you did are the same as in here?
3. Share related model files if possible
Cordially,
Iffa
Hi
i just followed what described here https://medium.com/openvino-toolkit/unleashing-the-power-of-model-optimization-and-benchmarking-with-intel-deep-learning-workbench-on-2e9f589aa098
And just to make sure - I am not uploading the model. I am importing it.
I am trying to import one of available models and it doesn't work.
thank you
Cordially,
Iffa
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Cordially,
Iffa
