Edge Software Catalog
483 Discussions
Cant' install Robotics SDK on Radxa X4
maxxlife
while run $ sudo apt install ros-humble-robotics-sdk
Receive an error
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
ros-humble-cartographer-ros : Depends: libpcl-dev but it is not going to be installed
ros-humble-pcl-conversions : Depends: libpcl-dev but it is not going to be installed
ros-humble-pcl-ros : Depends: libpcl-dev but it is not going to be installed
ros-humble-pointcloud-groundfloor-segmentation : Depends: libpcl-dev but it is not going to be installed
ros-humble-rtabmap : Depends: libpcl-dev but it is not going to be installed
ros-humble-velodyne-pointcloud : Depends: libpcl-dev but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Platform Radxa X4 N100, Ubuntu 22.04
maxxlife
Version Ubuntu 22.04 IoT Dekstop for Intel® Atom® X7000E Series (Alder Lake N). Kernel after $apt upgrade became 5.15.0-1066-intel-iotg. Lower kernel 1049 has the same error.
