Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
Castle server
Rajnish
Getting following error while running
curl -u <username>
<csl_manager_url>/api/v1/configuration/server-bootstrap >
server-bootstrap.sh command while doing castle server setup.
Enter host password for user 'admin':
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
curl: (35) error:0407008A:rsa routines:RSA_padding_check_PKCS1_type_1:invalid padding
Jia-Shing_W_Intel
Did you follow the instructions to update the CA certificates with the newly created one for the CSL Manager? This needs to be done on the systems that host the CSL Manager, server, as well as clients. Please try it and let us know if it helps.
Rajnish
Thanks Shing issue is resolved now.
I have two further queries:
1.I am done with the installation of castle server.Documents suggest device status should be online but for me it is coming offline.How to make it online.
2.After installation if i am restarting the system.how to make castle server up again.
Jia-Shing_W_Intel
Glad I helped. About your questions,
Do you mean your server node status in the CSL Manager UI is offline? Do you see any significant error in your /opt/csl/csl-manager/app.log? Or perhaps you can attach it here.
If it's set up properly, the corresponding services and containers will start automatically when you restart the device that hosts the CSL Server.
