Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
Create New file and folder and reading from /opt/intel/eis/(new folder) with Orchestrator
Rekha07
Hi
Do I need to specify path of new folder I have created inside /opt/intel/eis in whitelisted_mounts.
WengWai_C_Intel
Hi @Rekha07
If you are creating the new directory in /opt/intel/eis/(new folder), it is not required to add it into whitelisted_mounts because the default setup step for CSL manager already added the /opt/intel/eis directory into whitelisted_mounts.
However, for the container that need to access that directory to read files, you will need to add the "TemporaryVolumes" into the container module spec file and register the updated module spec file with SMR or docker registry again. You can refer to Visualizer, VideoIngestion or VideoAnalytics module spec file as example that using "TemporaryVolumes" as well.
