Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
Discovery Tool Issue EII2.4.2
Saravanan_M
Hi currently using EII 2.4.2. While exploring discovery tools not able to retrieve the  frames from minio bucket.  Getting "NULL" as response.Getting "NULL" as responseGetting "NULL" as response
Sahira_Intel
Hi Saravanan_M,
This may be due to a connection error with minIO. Can you please post a screenshot of the commands you executed so I can try to reproduce this issue? Are you running this on Ubuntu 18.04?
I noticed you are using an older version of EII. The latest version is 2.6 so I recommend updating to the latest version of the software and retrying.
Sincerely,
Sahira
Saravanan_M
Hi Sahira_Intel,
As per your suggestion  I have tried Installing the latest version (2.6) but getting the same error again and again  while installation. Please find the error screenshot in the attachment.EII installer failed.EII installer failed.
Haizad_Intel
Hi! Saravanan,
The installation issue is caused by a bug in the installation script. A fixed will be released in EII v2.6.1 which will be released this week.
In the meantime, if you do not plan to use factory control app, you can remove it in the [work_DIR]/edge_insights_industrial/edgesoftware_configuration.xml.
Refer the following image:
Saravanan_M
Hi Haizad,
I have tried removing factory control app from edgesoftware_configuration.xml file. But getting the same error again.Screenshot from 2021-10-06 10-36-08.pngScreenshot from 2021-10-06 10-35-56.png
Sahira_Intel
Hi Saravanan_M,
Can you uninstall using the command edgesoftware uninstall -a, then delete edge_insights_industrial and re-create it by unzipping the download package. Once the new directory is created, you can edit edgesoftware_configuration,json and remove the factory_app line.
Sincerely,
Sahira
Saravanan_M
Hi Haizad,
Trying to use EII_2.6 Discovery Tool . But the Image of this tool is not available on the dockehub. Getting the below error.Screenshot from 2021-10-11 13-29-32.png
Murni_J_Intel
Hi @Saravanan_M
Can you list the current running docker container?
May I check if you are using the default PCB demo for this?
