Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
492 Discussions
ECI install issue
AmandaLee
I am trying to install ECI on Kabylake platform.
On this machine, the ECI USB boot stick is listed in BIOS boot menu but won't enter ECI install process (The ubuntu live USB is working fine with this machine.).
I have tried same USB stick on another machine and no problem.
Is there any suggestion about this?
Fail machine:
           CPU: Intel i5-7500T @2.7G (Kabylake)
           RAM: 8G
           BIOS vendor: American Megatrends
           UEFI 2.5
Success machine:
           CPI: Intel i7-1185G7E @2.8G (TGL)
           RAM: 16G
           UEFI 2.7
ECI target:
  1. ECI2.0 ECI-B poky
  2. ECI1.5 ECI-A acrn
USB boot stick : USB3.0
JesusE_Intel
Hi AmandaLee,
The system you are using (Intel i5-7500T) does not meet the system requirements for Edge Controls for Industrial. Could you try it on a different system that meets the requirements?
Jesus
JesusE_Intel
Hi AmandaLee,
Jesus
AmandaLee
Hi Jesus,
Thanks for your help!
Amanda
AmandaLee
Hi Jesus,
I would like to check this situation as the following:
  1. Why didn’t support Core i5-7500T? Because we found “IEI* TANK - TANK-870AI-i5KBL/8G/2A-R11 with Intel® Core™ i5-7500T” in Intel ECI Validated Target Systems list as the capture.
  2. Did ECI supported included Whiskey Lake & Coffee Lake-S in 8th Gen CPU?
  3. Did ECI supported included Coffee Lake-R & Coffee Lake-H in 9th Gen CPU?
Amanda
JesusE_Intel
Hi AmandaLee,
Thanks for pointing that out, let me check with my peers about this and get back to you.
Jesus
Lay
Hi AmandaLee,
Can you share your Kabylake system info(product link)? Can you try on different USB port or use USB2 pendrive?
Can you see grub menu? If yes, can you press 'e' in 'boot' entry and add debug=7 and provide the error log?
Lay
JesusE_Intel
Hi AmandaLee,
Could you please provide the error logs following Lay's suggestion?
Jesus
AmandaLee
Hi Jesus,
The machine that I use is borrowed from other team and already returned.
I am still waiting on them to provide me again.
I will update to you as soon as I finish it.
Amanda
JesusE_Intel
Hi Amanda,
Would you mind if I close this discussion and we can start a new one once you get access to the system?
Jesus
AmandaLee
Hi Jesus,
Okay, if there is any question later, i will start a new one.
Thanks for your assistance.
Amanda
JesusE_Intel
Great, thank you! If you need any additional information, please submit a new question as this thread will no longer be monitored.
