Edge Software Catalog
488 Discussions
ECI poky-base image build fails when retrieving /coreos/go-systemd.git
EstebanV_Altera
I', trying to build ECI image (poky-base), the build fails when trying to pull files from git://github.com/coreos/go-systemd.git
The log has the following:
WARNING: go-systemd-4+gitAUTOINC+b4a58d9518-r0 do_fetch: Failed to fetch URL git://github.com/coreos/go-systemd.git, attempting MIRRORS if available
ERROR: go-systemd-4+gitAUTOINC+b4a58d9518-r0 do_fetch: Fetcher failure: Unable to find revision b4a58d95188dd092ae20072bac14cece0e67c388 in branch master even from upstream
ERROR: go-systemd-4+gitAUTOINC+b4a58d9518-r0 do_fetch: Fetcher failure for URL: 'git://github.com/coreos/go-systemd.git'. Unable to fetch URL from any source.
ERROR: Logfile of failure stored in: /home/demo/edge_controls_industrial/Edge_Controls_for_Industrial_2.0/Edge_Controls_for_Industrial/release-eci_2.0/eci-release/build/ecs-base-poky/build/tmp/work/corei7-64-ecs-linux/go-systemd/4+gitAUTOINC+b4a58d9518-r0/temp/log.do_fetch.28598
ERROR: Task (/home/demo/edge_controls_industrial/Edge_Controls_for_Industrial_2.0/Edge_Controls_for_Industrial/release-eci_2.0/eci-release/build/ecs-base-poky/layers/meta-virtualization/recipes-devtools/go/go-systemd_git.bb:do_fetch) failed with exit code '1'
Could you please advise?
Esteban Valverde
Lay
Can you try
#Edit this file.
#Add the red text in the file.
SRC_URI = "git://${PKG_NAME}.git;branch=main"
#After save. Then continue the build
cd /home/demo/edge_controls_industrial/Edge_Controls_for_Industrial_2.0/Edge_Controls_for_Industrial/release-eci_2.0/eci-release/build/ecs-base-poky/poky
source oe-init-build-env ../build
bitbake ecs-image-base-poky
Lay
Can you try
#Edit this file.
Sahira_Intel
If you need any additional information, please submit a new question as this thread will no longer being monitored.
Sincerely,
Sahira
