Edge Software Catalog
471 Discussions
EI for AMR v2021.3 (Q3 2021 Release) Navigation issue
Nadia_J_Intel
Hi all,
There is a known navigation issue for the Nav2 planner stack.
While navigating, the Robot looses or resets the costmap it created previously. Nav2 path planner creates a path through the wall and hits it.
It is a known bug in Nav2 path planner and similar to what has been reported at: https://github.com/ros-planning/navigation2/issues/1999
A patch will be available soon to fix the issue.
Nadia_J_Intel
Hi all,
As mentioned, the fix patch for the above issue is attached below. There is a readme in the zip file to help you execute the patch.
Nadia_J_Intel
Hi all,
