Edge Software Catalog
475 Discussions
EII PCB Defect Detection Build failare
TChio
sudo useradd -s /bin/bash -d /home/smartedge-open/ -m -G sudo smartedge-open
sudo passwd smartedge-open
echo "smartedge-open ALL=(ALL) NOPASSWD:ALL" | sudo tee /etc/sudoers.d/smartedge-open
ssh-keygen
sudo apt install unzip
unzip Smart_Edge_Open_Developer_Experience_Kits.zip
cd Smart_Edge_Open_Developer_Experience_Kits
chmod 755 edgesoftware
./edgesoftware install
that will hang。run ./edgesoftware install,when request entering IP :192.168.10.41 to SYNNEX-NUC02XH  but we entering it after 4 hrs still no any response . 1.png
Iffa_Intel
any chance that you are behind a proxy network? You'll need to ensure that proxy addresses are configured in the system if you are.
https_proxy=<proxy-address>:<proxy-port>
http_proxy=<proxy-address>:<proxy-port>
HTTP_PROXY=<proxy-address>:<proxy-port>
HTTPS_PROXY=<proxy-address>:<proxy-port>
ftp_proxy=<proxy-address>:<proxy-port>
no_proxy=<list of proxies with your machine ip>
NO_PROXY=<list of proxies with your machine ip>
all_proxy=<socks>:<proxy-address>:<port>
Cordially,
Iffa
TChio
Hi Cordially :
we don't used Proxy .
we reboot and run it still meet the address hang up problem . could we know what the IP address is own machine address ?
below is the command after install server20.04 photo for you reference .
11
Iffa_Intel
are you able to download/wget or ping 8.8.8.8 (Google DNS server) on that machine? (best to test download using command).
This is to determine whether the installer or your setup has issues.
Cordially,
Iffa
TChio
Hi Coridally :
Hi, I am able to ping 8.8.8.8 and wget http://www.google.com .
Iffa_Intel
this solution might help you.
Another option is to try on a different network, check your IP using ifconfig command and try to see whether the new network works.
Cordially,
Iffa
Iffa_Intel
We will further investigate this and get back to you.
Cordially,
Iffa
Iffa_Intel
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Cordially,
Iffa
