Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
EII connect TLS Remote Agent have json error message
Tconnell
Hi Intel,
I want to try EII connect TLS by remote agent.
But it have error message, include SecMode and DevMode.
error message:
2021-08-29 18:30:04,228 : INFO : Insecure Mode : root : [util.py] :validate_json : in line : [111] : JSON schema validation passed !
No protocol specified
Traceback (most recent call last):
File "tls_remote_agent.py", line 644, in <module>
main()
File "tls_remote_agent.py", line 570, in main
window = Tk()
File "/usr/lib/python3.6/tkinter/__init__.py", line 2023, in __init__
self.tk = _tkinter.create(screenName, baseName, className, interactive, wantobjects, useTk, sync, use)
_tkinter.TclError: couldn't connect to display ":0"
BTW:
EII default is run PCB demo, so when I deploy model from TLS
TLS-View(inference) is run "./test_video/pcb_d2000.avi" ,correct?
So I need to change video/image path, correct?
JesusE_Intel
Hi Tconnell,
From the error: couldn't connect to display ":0"
It looks like the application cannot open display 0. Could you confirm your display number by running who command in your terminal? Once identified, update the DISPLAY variable accordingly.
Take a look at this discussion as well:
https://community.intel.com/t5/Intel-Edge-Software-Hub/xhost-doesn-t-work/m-p/1196271/highlight/true
Jesus
JesusE_Intel
Hi Tconnell,
Jesus
JesusE_Intel
