Edge Software Catalog
486 Discussions
ERROR - Failed to install Automated_License_Plate_Recognition. tuple index out of range
MohammedSaif
Hi everyone,
I am trying to implement the following use case on a Ubuntu Machine.
https://www.intel.com/content/www/us/en/developer/articles/reference-implementation/automated-license-plate-recognition.html
However, i keep getting this error - Failed to install Automated_License_Plate_Recognition. tuple index out of range.
Ubuntu version - 20.04.4 LTS
Last few lines of the log file-
Wed Aug 03 02:12:53 IST 2022 - ERROR - Failed to install Automated_License_Plate_Recognition. tuple index out of range
Wed Aug 03 02:12:53 IST 2022 - INFO - Updating status in log file for Automated_License_Plate_Recognition as FAILED
Wed Aug 03 02:12:53 IST 2022 - INFO - Successfully updated status in log file for Automated_License_Plate_Recognition
Wed Aug 03 02:12:53 IST 2022 - ERROR - Failed to connect. Please check the Internet connection and proxy settings and retry. HTTPSConnectionPool(host='edgesoftwarehub.intel.com', port=443): Max retries exceeded with url: /recipe/6241c176bc27a5002cca6692 (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f8d51b5e070>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
Wed Aug 03 02:12:53 IST 2022 - ERROR - Failed to get package and modules details.
Wed Aug 03 02:12:53 IST 2022 - ERROR - Failed to send telemetry report to LanternRock cannot import name 'LanternRock' from 'lanternrock' (unknown location)
Wed Aug 03 02:12:54 IST 2022 - INFO - Sending installation report
Wed Aug 03 02:12:54 IST 2022 - ERROR - Failed to connect. Please check the Internet connection and proxy settings and retry. HTTPSConnectionPool(host='edgesoftwarehub.intel.com', port=443): Max retries exceeded with url: /analytics (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f8d51b5e0a0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
Wed Aug 03 02:12:54 IST 2022 - INFO - Installation of package complete
JesusE_Intel
Hi MohammedSaif,
Are you okay with closing this discussion too as you have a working reference implementation per our other discussion?
Solved: Docker configuration manager agent did not finish provisioning in time - Intel Communities
By the way, the original error in this discussion was due to the user not having the correct docker permissions. I ran into the same error and resolved by running the following commands:
groupadd docker
usermod -a -G docker $USER
reboot
Jesus
JesusE_Intel
Hi MohammedSaif,
I am also seeing the same error on a fresh Ubuntu 20.04 system. I have escalated the issue to development team for further investigation. I will let you know what I find out.
Jesus
MohammedSaif
Hey Jesus,
So i decided to reinstall ubuntu 20.04 LTS. I am now getting the above error during the installation of Automated License Plate Recognition. Did you get a reply back from the dev team?
SShan_Intel
Hi MohammedSaif,
Could you try to install with sudo? sudo ./edgesoftware install
SShan
MohammedSaif
Hey Sshan, thanks for your reply. I was able to resolve that error. The next issue i am facing is with the make webui command. After the installation, when i runthe below command, it gives me a makefile error.
saif@saif-Latitude-7520:~/Desktop/LPR/automated_license_plate_recognition/Automated_License_Plate_Recognition_2022.1/Automated_License_Plate_Recognition/EII-LicensePlateRecognition-UseCase$ make webui EII_BASE= Desktop/LPR/Automated_License_Plate_Recognition_2022.1/IEdgeInsights REPO_FOLDER= Desktop/LPR/automated_license_plate_recognition/Automated_License_Plate_Recognition_2022.1/Automated_License_Plate_Recognition/EII-LicensePlateRecognition-UseCase
fatal: not a git repository (or any of the parent directories): .git
xhost +
access control disabled, clients can connect from any host
# Activate virtual env and Launch WebUI
cd src/webui && source /".uc_virtual_env"/bin/activate && python3 ./server.py
/bin/bash: /.uc_virtual_env/bin/activate: No such file or directory
make: *** [Makefile:101: webui] Error 1
Any pointers on what could be the problem here?
SShan_Intel
Hi MohammedSaif,
You are missing / in front of Desktop:
make webui EII_BASE=/Desktop/LPR/Automated_License_Plate_Recognition_2022.1/IEdgeInsights REPO_FOLDER= /Desktop/LPR/automated_license_plate_recognition/Automated_License_Plate_Recognition_2022.1/Automated_License_Plate_Recognition/EII-LicensePlateRecognition-UseCase
SShan
MohammedSaif
Hi Sshan, tried that. Here's the output
saif@saif-Latitude-7520:~/Desktop/LPR/automated_license_plate_recognition/Automated_License_Plate_Recognition_2022.1/Automated_License_Plate_Recognition/EII-LicensePlateRecognition-UseCase$ make webui EII_BASE=/Desktop/LPR/Automated_License_Plate_Recognition_2022.1/IEdgeInsights REPO_FOLDER= /Desktop/LPR/automated_license_plate_recognition/Automated_License_Plate_Recognition_2022.1/Automated_License_Plate_Recognition/EII-LicensePlateRecognition-UseCase
xhost +
SShan_Intel
Hi MohammedSaif,
Based on the error, it says the path is not exist. Could you verify it ? make sure you are in directory:
cd /Desktop/LPR/automated_license_plate_recognition/Automated_License_Plate_Recognition_2022.1/Automated_License_Plate_Recognition/EII-LicensePlateRecognition-UseCase
Then check if this file exist from your end.
$ ls -ld .uc_virtual_env/bin/activate
-rw-r--r-- 1 intel intel 2359 Ogos 5 16:41 .uc_virtual_env/bin/activate
The file should be installed during package installation.
SShan
MohammedSaif
Hi Sshan,
Yes i can confirm that i am in that directory. Also ran the command you mentioned in the same directory. Here's the output:
saif@saif-Latitude-7520:~/Desktop/LPR/automated_license_plate_recognition/Automated_License_Plate_Recognition_2022.1/Automated_License_Plate_Recognition/EII-LicensePlateRecognition-UseCase$ ls -ld .uc_virtual_env/bin/activate
-rw-r--r-- 1 saif saif 2370 Aug 10 16:12 .uc_virtual_env/bin/activate
SShan_Intel
Hi Saif,
I just notice that the make gui command you are missing a folder name. Could you try if it work? I tested from my end, i dont have issue running make webui command.
saif@saif-Latitude-7520:~/Desktop/LPR/automated_license_plate_recognition/Automated_License_Plate_Recognition_2022.1/Automated_License_Plate_Recognition/EII-LicensePlateRecognition-UseCase$ make webui EII_BASE=/Desktop/LPR/automated_license_plate_recognition/Automated_License_Plate_Recognition_2022.1/IEdgeInsights REPO_FOLDER= /Desktop/LPR/automated_license_plate_recognition/Automated_License_Plate_Recognition_2022.1/Automated_License_Plate_Recognition/EII-LicensePlateRecognition-UseCase
SShan
MohammedSaif
Hi SShan, tried that. Still the same error as above
JesusE_Intel
Hi MohammedSaif,
groupadd docker
reboot
Jesus
MohammedSaif
Hi Jesus,
Thank you for providing a solution to the original error and please accept my apologies for the delay in my reply. And yes, I am okay with closing this discussion.
Saif
JesusE_Intel
