Edge Software Catalog
486 Discussions
ESDQ 6.0 on ElKhart Lake Platform
pw2
Hi
I run ESDQ 6.0 on Elkhart lake platform and there are some failed items . Also, when I run ESDQ 5.0 on Elkhart lake platform, there are only two failed items. Can you make some suggestions for failed  items ?
Jason
pw2
Hi JesusE,
I have tried the methods the Intel website provides, but it still does not work.
After updating the kernel version from 5.13.0-40-generic to 5.16.0-051600-generic, the result of the ESDQ test can pass all of the test items.
Jason
JesusE_Intel
Hi Jason,
Couple of questions for you:
Depending on the package you are using a specific kernel version may be required for example, ESDQ package requires Kernel Version 5.4 or 5.8 when using Ubuntu 20.04.
Jesus
pw2
Hi Jesus
1.When using Ubuntu20.04.4, the kernel version is 5.13.0-40-generic.
2.Below are the detailed information
   VGA compatible controller: Intel Corporation Device 4571 (rev 01)
   DeviceName: Onboard - Video
   Subsystem: Intel Corporation Device 7270
   Kernel modules: i915
3.I am using Intel® ESDQ for Vision .
Jason
JesusE_Intel
Hi Jason,
Thanks for confirming! That should meet the system requirements. Could you follow the steps in the troubleshooting section in Intel® Edge Software Device Qualification (Intel® ESDQ)? Specifically the Media sdk sample encode test failed, openvino GPU tests failed and Intel® Distribution of OpenVINO™ toolkit Prerequisites sections.   Let me know if this solves your issues.
Jesus
pw2
Hi JesusE,
Jason
JesusE_Intel
Hi pw2,
I'm glad your system is passing all tests. For Intel Atom® x6000E processor series, Kernel 5.11 is needed but I'm glad version 5.16 is working for you.
Jesus
