Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
Edit MQTT configuration
HuynhVanThuan
Currently I'm having a problem with configuring MQTT. I conldn't find this configuration file after reinstalling my ubuntu OS. How should i get this configuration file in my computer.
Huynh
JesusE_Intel
Hi Huynh,
I am not familiar with the guide you are following and if there is any specific settings are needed before updating the config file. However, from a generic Linux perspective uninstalling the package should generate the default configuration file.
sudo apt purge --autoremove -y mosquitto
sudo apt install mosquitto
Jesus
JesusE_Intel
Hi Huynh,
Jesus
HuynhVanThuan
Hi JesusE,
Thanks for your supports. These command lines are really helpful with me so i can consider this as your right solution.
Regard,
Huynh
JesusE_Intel
Thank you for confirming. If you need any additional information, please submit a new question as this thread will no longer be monitored.
