Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
492 Discussions
ESDQ-AIBOX v2.6 aibox_metrics Failed
huang__shiuan-chi
Our customer used ESDQ-AIBOX v2.6 verify their J6412 Platform.
All the test suites can pass except ai_box test module.
We found an error when running tensorflow-related operations, such as model optimizer, because tensorflow was built for platforms with AVX instruction sets.
I’m not sure whether this is the main cause or whether there are ways to avoid and pass this test module.
JesusE_Intel
Hi huang__shiuan-chi,
Thank you for your patience while we investigated the reported issue. We have determined that AVX is required for TensorFlow benchmarks. Looking at the logs, there are any results missing due to AVX unavailability.
----Starting benchmark docker commands -------
Executing benchmark setup environment...
The TensorFlow library was compiled to use AVX instructions, but these aren't available on your machine.
Please let me know if you have any further questions.
Jesus
JesusE_Intel
I was able to reproduce the ai_box test module fail on a system with Intel Celeron J6412 without AVX. I then tested the on a system with an Intel Core i7-1165G7 that has AVX and the ai_box test module passed. Let me reach out to the development team to confirm if the test module requires AVX or if there is a solution.
Jesus
huang__shiuan-chi
Hi is there any update about the non-AVX platform?
JesusE_Intel
Jesus
JesusE_Intel
