Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
[ESDQ-ECI] Network Connection Error in TSN Module Testing
chiao
Dear Sir,
We are testing ESDQ-ECI, and when executing the TSN module test item "Dual DUT Setup for TSN," we encounter an issue right at the start when executing the case "IEEE 802.1Qbv Time Aware Shaper." The IP address of Board A (192.168.1.1) gets changed, leading to network connection errors. Ultimately, we see the error message "ERROR: Configure Qdisc failed."
The log file has been attached.
Do you have any suggestions for this issue? Thank you!!
Test platform : Ubuntu 22.04
ESDQ for ECI softawre version : 2023.2
Thanks & Regards,
Denise
Iffa_Intel
Could you clarify:
  1.  The IP address of Board A (192.168.1.1) gets changed automatically due to network or you manually change it?
  2. Are you using any proxy?
  3. Did you try to configure static IP address on your system? (this is more related to system's network configuration instead of ECI actually)
  4. Did you try to use some other network that is possibly more stable?
  5. Does your Network Adaptors support TSN?:
Cordially,
Iffa
chiao
Hi Iffa,
    =>  It gets changed automatically, we didn't manually change it.
    => No, we didn't use any proxy.
    => Yes, we configured static IP address
    => This test directly connects two devices using a network cable, with Board A set to 192.168.1.1 and Board B set to 192.168.1.2. Therefore, I'm not quite sure what you mean by using another more stable network.
    => Sure, we use I226-IT and I226-LM.
Thanks & Regards,
Denise
Iffa_Intel
Thanks for the information.
We'll further investigate this.
Cordially,
Iffa
Iffa_Intel
Could you please try the latest ESDQ for ECI version 2024.1 and specify the IP address of your BOARD_A and BOARD_B in the following configuration file
<edge_software_device_qualification>/Edge_Software_Device_Qualification_For_RTPM_2024.1/ESDQ/modules/TSN_Test_Module/test_cfg
Once specified,try to run this command esdq --verbose module run TSN in the <edge_software_device_qualification>/Edge_Software_Device_Qualification_For_RTPM_2024.1/ESDQ directory and share the output.
Cordially,
Iffa
Iffa_Intel
Thank you for your question. If you need any additional information from Intel, please submit a new question as Intel is no longer monitoring this thread.
Cordially,
Iffa
