Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
492 Discussions
[ESQ for AI Edge system] The images.py script failed during testing
AmandaLee
Hi Expert,
I encountered an issue while testing with "ESQ for AI Edge system." When I ran the esq run command, the "images.py" failed.
OS: Ubuntu 24.04
Platform: MTL 155H
ESQ for AI Edge System version: 11.2.1
Could you please provide any suggestions to help resolve this?
Amanda
JesusE_Intel
The issue is caused by conflicts in python packages due to recent changes in 3rd party dependency versions. To resolve this, please apply the following patch.
Steps:
1. Uninstall the ESQ package completely first:
 # Inside the software package location
  • ./edgesoftware uninstall -a
  •  cd ~/
  • sudo rm -rf ~/esq
2. Reinstall the ESQ as usual following the official guide.
3. Ensure that the environment is thoroughly cleaned. Running the command below:
  • docker container prune -f && docker images -q | xargs docker rmi -f
  • docker system prune -f
  • cd ~/
  • sudo rm -rf .cache
4. Apply the patch file ESQ 11.2.1-Intel AI Edge System that is attached in this comment.
  • Copy the patch file to ~/esq
  • Run "cd ~/esq"
  • Run "patch -p1 < final.patch"
  • Paste "modules/ai-edge-system/genAI/Dockerfile" for the file to patch
  • For the second time it asks, paste "modules/ai-edge-system/genAI/Dockerfile.vllm.ov" for the file to patch.
5. Proceed to the normal ESQ run command.
Zulkifli_Intel
Hi AmandaLee,
Thank you for reaching out.
I'm not able to run the Intel ESQ as well:
Could you please share the steps you took from installation to running the module?
Zul
AmandaLee
Hi Zull,
I followed the steps on the ESQ for AI Edge system and ESQ get started.
1. Installed a fresh Ubuntu 24.04
2. Prerequisites
$ sudo apt-get install libnuma-dev python3-dev jq
$ export HF_TOKEN=.....
$ ### Set up Docker
3. Install ESQ
$ unzip edge_system_qualification.zip
$ cd edge_system_qualification/
$ chmod +x edgesoftware
$ sudo apt install python3-venv
$ python3 -m venv venv
$ ./edgesoftware install
4. Run ESQ
$ cd ~/esq
$ esq --verbose run
Please refer to the attachments for "esq" and console log.
Thank you.
Amanda
Zulkifli_Intel
Hi AmandaLee,
Thank you for sharing the logs and steps taken to reproduce the issue. I'll check with the dev team for troubleshooting.
Zul
JesusE_Intel
Hi AmandaLee,
Thank you for providing the steps you took and log files. Just to confirm, did you install the drivers for your system using the script mentioned in the Getting Started Guide?
https://www.intel.com/content/www/us/en/developer/articles/guide/esq-for-ai-edge-systems.html#inpage-nav-2-undefined
Install the required drivers with the corresponding Intel AI Edge Systems configuration as mentioned in the VRB guidelines. To speed up system driver and library installation, go to Edge Developer Kit Reference Scripts, and then select the appropriate scripts for the target platform.
Jesus
AmandaLee
Hi Jesus,
I have tried Ubuntu 22.04, and after running the Edge Developer Kit Reference Scripts, I encountered the same error when running ESQ.
I know Zul ran into this before, has the issue been fixed? If so, what was the solution?
Amanda
JesusE_Intel
Steps:
  •  cd ~/
  • sudo rm -rf ~/esq
  • cd ~/
  • Run "cd ~/esq"
AmandaLee
Hi Jesus,
Thanks, the patch resolved the issue.
Amanda
JesusE_Intel
Thank you for confirming. If you need further assistance, please create a new discussion as this one will no longer be monitored.
