Edge Software Catalog
Annonces
478 Discussions
[Edge Software Configurator][v4.0] Can't deploy a local created VM in host to Edge nodes
RWu
Nouveau contributeur I
2 077 Visites
Hi all,
I follow the documents: https://www.intel.com/content/www/us/en/develop/documentation/edge-software-configurator-doc/edge-software-configurator-basics/create-and-manage-virtual-machines/create-virtual-machine-with-new-template.html to create a windows VM by a local windows ISO file.  But I can't use this VM in the steps "Select Virtual Machine" in "Add Workload Template" of "Deploy Edge Nodes". Therefore, I can't deploy a Windows VM to a  edge node.
I also found that only the VM created by a default "Virtual Machine Template" ("Ubuntu 18.04 Headless" and "Ubuntu 18.04 Desktop") can be show in the steps "Select Virtual Machine" .
Example: I created 5 VM as below picture, but only two of them can be show in "Add Workload Template Page"
How to make the local created VM can be deployed on the remote edge nodes?
Étiquettes (1)
0 Compliments
6 Réponses
Sahira_Intel
Modérateur
2 029 Visites
Hi RWu,
It looks like the other three virtual machines you created are not being properly recognized as the OS Version is listed as "generic". How were these VMs created? Did you disable the "Enable v-GPU" flag in the virtual machine template creation step?
Sincerely,
Sahira
0 Compliments
RWu
2 007 Visites
Hi Sahira,
The way I created VM is follow the documents https://www.intel.com/content/www/us/en/develop/documentation/edge-software-configurator-doc/edge-software-configurator-basics/create-and-manage-virtual-machines/create-virtual-machine-with-new-template.html to create our-self VM, the OS Version option we can choose is only "Generic". I am not sure is this limitation or something else.
Best regard,
Kunyang
0 Compliments
Sahira_Intel
Modérateur
1 961 Visites
Hi Kunyang,
I am looking into this for you and will respond as soon as possible.
Sincerely,
Sahira
0 Compliments
RWu
1 848 Visites
Hi Sahira,
Is any update we can follow ?
Best regard,
0 Compliments
Sahira_Intel
Modérateur
1 842 Visites
Hi Kunyang,
There is no update from the Engineering team yet, but I will let you know as soon as there is.
Sincerely,
Sahira
0 Compliments
Sahira_Intel
Modérateur
1 828 Visites
Hi Kunyang,
It looks like the "Add Workload Template" functionality is currently only supported for the original template in Edge Software Configurator. For VMs that are created using an ISO image, it won't be listed in the "Add Workload Template". This is a known limitation but will be made available in the next ESC release.
I hope this is helpful.
Sincerely,
Sahira
0 Compliments
Répondre
