Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
492 Discussions
Edge insight software installation Failing
Rajnish
I am getting following error while installing Eis:-
Failed to provision secrets to vault...!!
PFA
Request for earlier help.
Murni_J_Intel
Hi @Rajnish
I will look into this issue and get back to you as soon as possible. May I know if this is a fresh system or the previous version has been installed here before?
Murni_J_Intel
Hi @Rajnish
The issue seems like you are having a different version of PyYAML from the requirement. It should use PyYAML version  PyYAML-5.1.1.  You can uninstall the existing version manually and install the PyYAML version-5.1.1 as per below command
pip3 install PyYAML==5.1.1
 After doing the above installation, you can re-run again the ./edgesoftware install command.
Rajnish
Thank you so much...!!
Issue is resolve now.
