Edge Software Catalog
471 Discussions
Edgesoftware ONNX build fail
premp
I am using Intel® Edge Software Device Qualification (ESDQ) to generate report for hardware.
After running "./edgeSoftware install" command all the modules are build successful and ONNX build is getting failed with below errors:
Error:Failed to build onnxruntime
Failed command:./build.sh --config RelWithDebInfo --use_openvino CPU_FP32 --build --update --build_wheel  --parallel
Failed to install ONNX_Runtime took 9 minutes 20.14 seconds
Configuration used to run:
OS: Ubuntu 20.4.2
RAM: 16GB
Python: 3.8.2
JesusE_Intel
Hi premp,
Is this a fresh Ubuntu 20.04 system? Could you provide the following log files?
/var/log/esb-cli/Edge_Software_Device_Qualification_3.0/output.log
/var/log/esb-cli/Edge_Software_Device_Qualification_3.0/esdq/install.log
Jesus
premp
HI Jesus,
I have the logs for the installation I tried on Ubuntu 18.04 where I faced the same issue of ONNX Build failed. Please find both logs below.
Wed Aug 11 01:04:19 IST 2021 - INFO - ESB CLI version: 2021.1
Target OS: Ubuntu 18.04
Wed Aug 11 01:04:20 IST 2021 - INFO - Python version: 3.6.9
Wed Aug 11 01:04:20 IST 2021 - INFO - Checking Internet connection
Wed Aug 11 01:04:20 IST 2021 - INFO - Connected to the Internet
Wed Aug 11 01:04:20 IST 2021 - INFO - Validating product key
Wed Aug 11 01:04:21 IST 2021 - INFO - Successfully validated Product Key
Wed Aug 11 01:04:21 IST 2021 - INFO - Connected to a network in United States
Wed Aug 11 01:04:21 IST 2021 - INFO - Checking for prerequisites
Wed Aug 11 01:04:25 IST 2021 - INFO - Installing prerequisites. This may take some time...
Wed Aug 11 01:05:04 IST 2021 - INFO - --------Succesfuly installed prerequisites--------
Wed Aug 11 01:05:04 IST 2021 - INFO - All dependencies met
Wed Aug 11 01:05:05 IST 2021 - INFO - -------------------SYSTEM INFO--------------------
Wed Aug 11 01:05:05 IST 2021 - INFO - Package Name: Edge Software Device Qualification 3.0
Wed Aug 11 01:05:05 IST 2021 - INFO - Product Name: <Product Name>
Wed Aug 11 01:05:05 IST 2021 - INFO - CPU SKU: Intel(R) Xeon(R) Gold 6330 CPU @ 2.00GHz
Wed Aug 11 01:05:05 IST 2021 - INFO - Memory Size: 15 GB
Wed Aug 11 01:05:05 IST 2021 - INFO - Operating System: Ubuntu 18.04.5 LTS
Wed Aug 11 01:05:05 IST 2021 - INFO - Kernel Version: 5.4.0-80-generic
Wed Aug 11 01:05:05 IST 2021 - INFO - Accelerator: None
Wed Aug 11 01:05:05 IST 2021 - INFO - CPU Utilization: 0.6%
Wed Aug 11 01:05:05 IST 2021 - INFO - Available System Memory: 408 GB
Wed Aug 11 01:05:06 IST 2021 - INFO - Starting installation
Wed Aug 11 01:05:06 IST 2021 - INFO - Modules to be downloaded by package are ['esb_common', 'Amazon_Web_Services_Greengrass_Prerequisites', 'K3s_Lightweight_Kubernetes', 'Azure_IoT_Edge_Prerequisites', 'Intel_Distribution_of_OpenVINO_toolkit_2021_3_Runtime', 'Deep_Learning_DL_Streamer_Pipelines', 'Docker_Community_Edition_CE', 'Intel_Distribution_of_OpenVINO_toolkit_2021_3_Container', 'Docker_Compose', 'edgex_foundry', 'ONNX_Runtime', 'RI_MultiCamera_Social_Distancing', 'Connect_Edge_Devices_to_Azure_IoT', 'esdq/Vision_Test_Module', 'esdq', 'esdq/VATS_Test_Module']
Wed Aug 11 01:05:06 IST 2021 - INFO - Downloading modules...
Wed Aug 11 01:05:06 IST 2021 - INFO - Downloading component esb_common
Wed Aug 11 01:05:06 IST 2021 - INFO - Sending request to download module 5e8c4742e02f17002a2a6976
Wed Aug 11 01:05:08 IST 2021 - INFO - Sending request to validate module 5e8c4742e02f17002a2a6976 with hash value 6914ceadfd836157c6642d761c7c47f7
Wed Aug 11 01:05:08 IST 2021 - INFO - Module validation passed for 5e8c4742e02f17002a2a6976
Wed Aug 11 01:05:08 IST 2021 - INFO - Successfully downloaded module esb_common
Wed Aug 11 01:05:08 IST 2021 - INFO - Downloading component Amazon_Web_Services_Greengrass_Prerequisites
Wed Aug 11 01:05:08 IST 2021 - INFO - Sending request to download module 601c2f303eb151002ace2c3b
Wed Aug 11 01:05:09 IST 2021 - INFO - Sending request to validate module 601c2f303eb151002ace2c3b with hash value 24d580ce9e4a97fa3e813c0447a2cb34
Wed Aug 11 01:05:10 IST 2021 - INFO - Module validation passed for 601c2f303eb151002ace2c3b
Wed Aug 11 01:05:10 IST 2021 - INFO - Successfully downloaded module Amazon_Web_Services_Greengrass_Prerequisites
Wed Aug 11 01:05:10 IST 2021 - INFO - Downloading component K3s_Lightweight_Kubernetes
Wed Aug 11 01:05:10 IST 2021 - INFO - Sending request to download module 605c61985a4b53002c27263b
Wed Aug 11 01:05:11 IST 2021 - INFO - Sending request to validate module 605c61985a4b53002c27263b with hash value 9252909dec0a3cdbb4999098902df7ab
Wed Aug 11 01:05:11 IST 2021 - INFO - Module validation passed for 605c61985a4b53002c27263b
Wed Aug 11 01:05:11 IST 2021 - INFO - Successfully downloaded module K3s_Lightweight_Kubernetes
Wed Aug 11 01:05:11 IST 2021 - INFO - Downloading component Azure_IoT_Edge_Prerequisites
Wed Aug 11 01:05:11 IST 2021 - INFO - Sending request to download module 5fff12aa54e210002a5f52b4
Wed Aug 11 01:05:14 IST 2021 - INFO - Sending request to validate module 5fff12aa54e210002a5f52b4 with hash value 30f8e489a24ec7f73052097db9850c79
Wed Aug 11 01:05:15 IST 2021 - INFO - Module validation passed for 5fff12aa54e210002a5f52b4
Wed Aug 11 01:05:15 IST 2021 - INFO - Successfully downloaded module Azure_IoT_Edge_Prerequisites
Wed Aug 11 01:05:15 IST 2021 - INFO - Downloading component Intel_Distribution_of_OpenVINO_toolkit_2021_3_Runtime
Wed Aug 11 01:05:15 IST 2021 - INFO - Sending request to download module 605c63865a4b53002c27263c
Wed Aug 11 01:05:17 IST 2021 - INFO - Sending request to validate module 605c63865a4b53002c27263c with hash value 86d81835816500162493398299555f52
Wed Aug 11 01:05:17 IST 2021 - INFO - Module validation passed for 605c63865a4b53002c27263c
Wed Aug 11 01:05:17 IST 2021 - INFO - Successfully downloaded module Intel_Distribution_of_OpenVINO_toolkit_2021_3_Runtime
Wed Aug 11 01:05:17 IST 2021 - INFO - Downloading component Deep_Learning_DL_Streamer_Pipelines
Wed Aug 11 01:05:17 IST 2021 - INFO - Sending request to download module 605c656c5a4b53002c27263f
Wed Aug 11 01:05:19 IST 2021 - INFO - Sending request to validate module 605c656c5a4b53002c27263f with hash value 16fde3148e2228668edc2978af5714f5
Wed Aug 11 01:05:20 IST 2021 - INFO - Module validation passed for 605c656c5a4b53002c27263f
Wed Aug 11 01:05:20 IST 2021 - INFO - Successfully downloaded module Deep_Learning_DL_Streamer_Pipelines
Wed Aug 11 01:05:20 IST 2021 - INFO - Downloading component Docker_Community_Edition_CE
Wed Aug 11 01:05:20 IST 2021 - INFO - Sending request to download module 5f21392e9e63c9002a6fd88d
Wed Aug 11 01:05:21 IST 2021 - INFO - Sending request to validate module 5f21392e9e63c9002a6fd88d with hash value 27f50c91517b3b6bb8d27d43aaa5d25f
Wed Aug 11 01:05:21 IST 2021 - INFO - Module validation passed for 5f21392e9e63c9002a6fd88d
Wed Aug 11 01:05:21 IST 2021 - INFO - Successfully downloaded module Docker_Community_Edition_CE
Wed Aug 11 01:05:21 IST 2021 - INFO - Downloading component Intel_Distribution_of_OpenVINO_toolkit_2021_3_Container
Wed Aug 11 01:05:21 IST 2021 - INFO - Sending request to download module 605c68865a4b53002c27264d
Wed Aug 11 01:05:22 IST 2021 - INFO - Sending request to validate module 605c68865a4b53002c27264d with hash value fad47dd64eed3c693c587efd6449708f
Wed Aug 11 01:05:23 IST 2021 - INFO - Module validation passed for 605c68865a4b53002c27264d
Wed Aug 11 01:05:23 IST 2021 - INFO - Successfully downloaded module Intel_Distribution_of_OpenVINO_toolkit_2021_3_Container
Wed Aug 11 01:05:23 IST 2021 - INFO - Downloading component Docker_Compose
Wed Aug 11 01:05:23 IST 2021 - INFO - Sending request to download module 5f213aae9e63c9002a6fd88e
Wed Aug 11 01:05:24 IST 2021 - INFO - Sending request to validate module 5f213aae9e63c9002a6fd88e with hash value da574df823cb3f64fd751fa2b612b4e5
Wed Aug 11 01:05:24 IST 2021 - INFO - Module validation passed for 5f213aae9e63c9002a6fd88e
Wed Aug 11 01:05:24 IST 2021 - INFO - Successfully downloaded module Docker_Compose
Wed Aug 11 01:05:24 IST 2021 - INFO - Downloading component edgex_foundry
Wed Aug 11 01:05:24 IST 2021 - INFO - Sending request to download module 605c6d045a4b53002c272654
Wed Aug 11 01:05:25 IST 2021 - INFO - Sending request to validate module 605c6d045a4b53002c272654 with hash value 290d2a48673f86e6dced01134bd8a3ac
Wed Aug 11 01:05:26 IST 2021 - INFO - Module validation passed for 605c6d045a4b53002c272654
Wed Aug 11 01:05:26 IST 2021 - INFO - Successfully downloaded module edgex_foundry
Wed Aug 11 01:05:26 IST 2021 - INFO - Downloading component ONNX_Runtime
Wed Aug 11 01:05:26 IST 2021 - INFO - Sending request to download module 606ecbb5b6706a00391e1cb3
Wed Aug 11 01:05:27 IST 2021 - INFO - Sending request to validate module 606ecbb5b6706a00391e1cb3 with hash value 5d33ce6d31bd3920223caa47bd52f508
Wed Aug 11 01:05:27 IST 2021 - INFO - Module validation passed for 606ecbb5b6706a00391e1cb3
Wed Aug 11 01:05:27 IST 2021 - INFO - Successfully downloaded module ONNX_Runtime
Wed Aug 11 01:05:27 IST 2021 - INFO - Downloading component RI_MultiCamera_Social_Distancing
Wed Aug 11 01:05:27 IST 2021 - INFO - Sending request to download module 605c6f665a4b53002c272658
Wed Aug 11 01:05:29 IST 2021 - INFO - Sending request to validate module 605c6f665a4b53002c272658 with hash value dc2bdbdd74171db1973ed9b7ce89b543
Wed Aug 11 01:05:30 IST 2021 - INFO - Module validation passed for 605c6f665a4b53002c272658
Wed Aug 11 01:05:30 IST 2021 - INFO - Successfully downloaded module RI_MultiCamera_Social_Distancing
Wed Aug 11 01:05:30 IST 2021 - INFO - Downloading component Connect_Edge_Devices_to_Azure_IoT
Wed Aug 11 01:05:30 IST 2021 - INFO - Sending request to download module 605c70a95a4b53002c27265b
Wed Aug 11 01:05:31 IST 2021 - INFO - Sending request to validate module 605c70a95a4b53002c27265b with hash value 33a2a9a7ae6d97e486f15159f1946834
Wed Aug 11 01:05:32 IST 2021 - INFO - Module validation passed for 605c70a95a4b53002c27265b
Wed Aug 11 01:05:32 IST 2021 - INFO - Successfully downloaded module Connect_Edge_Devices_to_Azure_IoT
Wed Aug 11 01:05:32 IST 2021 - INFO - Downloading component esdq/Vision_Test_Module
Wed Aug 11 01:05:32 IST 2021 - INFO - Sending request to download module 608a3d977bc123002b7ebe8b
Wed Aug 11 01:05:36 IST 2021 - INFO - Sending request to validate module 608a3d977bc123002b7ebe8b with hash value 5827fbb1e86e130432018d88baefc7da
Wed Aug 11 01:05:36 IST 2021 - INFO - Module validation passed for 608a3d977bc123002b7ebe8b
Wed Aug 11 01:05:36 IST 2021 - INFO - Successfully downloaded module esdq/Vision_Test_Module
Wed Aug 11 01:05:36 IST 2021 - INFO - Downloading component esdq
Wed Aug 11 01:05:36 IST 2021 - INFO - Sending request to download module 6077ecafb6706a00391e1e61
Wed Aug 11 01:05:41 IST 2021 - INFO - Sending request to validate module 6077ecafb6706a00391e1e61 with hash value 05497c279503f54b63f7e516d796f2cb
Wed Aug 11 01:05:42 IST 2021 - INFO - Module validation passed for 6077ecafb6706a00391e1e61
Wed Aug 11 01:05:42 IST 2021 - INFO - Successfully downloaded module esdq
Wed Aug 11 01:05:42 IST 2021 - INFO - Downloading component esdq/VATS_Test_Module
Wed Aug 11 01:05:42 IST 2021 - INFO - Sending request to download module 6074a373b6706a00391e1cbf
Wed Aug 11 01:05:42 IST 2021 - INFO - Sending request to validate module 6074a373b6706a00391e1cbf with hash value 9bc71cbc32c1a8436dc9a6a3db799855
Wed Aug 11 01:05:43 IST 2021 - INFO - Module validation passed for 6074a373b6706a00391e1cbf
Wed Aug 11 01:05:43 IST 2021 - INFO - Successfully downloaded module esdq/VATS_Test_Module
Wed Aug 11 01:05:43 IST 2021 - INFO - Downloading modules completed...
Wed Aug 11 01:05:43 IST 2021 - INFO - Installing shared module 'esb_common'
Wed Aug 11 01:05:43 IST 2021 - INFO - Unzipping the shared module 'esb_common'...
Wed Aug 11 01:05:43 IST 2021 - INFO - Successfully installed shared module 'esb_common'.
Wed Aug 11 01:05:43 IST 2021 - INFO - Unzipping the module Amazon_Web_Services_Greengrass_Prerequisites...
Wed Aug 11 01:05:43 IST 2021 - INFO - Unzipping the module K3s_Lightweight_Kubernetes...
Wed Aug 11 01:05:43 IST 2021 - INFO - Unzipping the module Azure_IoT_Edge_Prerequisites...
Wed Aug 11 01:05:43 IST 2021 - INFO - Unzipping the module Intel_Distribution_of_OpenVINO_toolkit_2021_3_Runtime...
Wed Aug 11 01:05:44 IST 2021 - INFO - Unzipping the module Deep_Learning_DL_Streamer_Pipelines...
Wed Aug 11 01:05:44 IST 2021 - INFO - Unzipping the module Docker_Community_Edition_CE...
Wed Aug 11 01:05:44 IST 2021 - INFO - Unzipping the module Intel_Distribution_of_OpenVINO_toolkit_2021_3_Container...
Wed Aug 11 01:05:44 IST 2021 - INFO - Unzipping the module Docker_Compose...
Wed Aug 11 01:05:44 IST 2021 - INFO - Unzipping the module edgex_foundry...
Wed Aug 11 01:05:44 IST 2021 - INFO - Unzipping the module ONNX_Runtime...
Wed Aug 11 01:05:44 IST 2021 - INFO - Unzipping the module RI_MultiCamera_Social_Distancing...
Wed Aug 11 01:05:44 IST 2021 - INFO - Unzipping the module Connect_Edge_Devices_to_Azure_IoT...
Wed Aug 11 01:05:44 IST 2021 - INFO - Unzipping the module esdq/Vision_Test_Module...
Wed Aug 11 01:05:45 IST 2021 - INFO - Unzipping the module esdq...
Wed Aug 11 01:05:45 IST 2021 - INFO - Unzipping the module esdq/VATS_Test_Module...
Wed Aug 11 01:05:45 IST 2021 - INFO - Modules to be installed by package are ['Amazon_Web_Services_Greengrass_Prerequisites', 'K3s_Lightweight_Kubernetes', 'Azure_IoT_Edge_Prerequisites', 'Intel_Distribution_of_OpenVINO_toolkit_2021_3_Runtime', 'Deep_Learning_DL_Streamer_Pipelines', 'Docker_Community_Edition_CE', 'Intel_Distribution_of_OpenVINO_toolkit_2021_3_Container', 'Docker_Compose', 'edgex_foundry', 'ONNX_Runtime', 'RI_MultiCamera_Social_Distancing', 'Connect_Edge_Devices_to_Azure_IoT', 'esdq']
Wed Aug 11 01:05:45 IST 2021 - INFO - Imported module for Amazon_Web_Services_Greengrass_Prerequisites is <module 'esb_install' from '/home/test/Downloads/edge_software_device_qualification/Edge_Software_Device_Qualification_3.0/Amazon_Web_Services_Greengrass_Prerequisites/esb_install.so'>
Wed Aug 11 01:05:45 IST 2021 - ERROR - Failed to verify the installation status of the component due to error Expecting value: line 1 column 1 (char 0)
Wed Aug 11 01:05:45 IST 2021 - INFO - Installing Amazon_Web_Services_Greengrass_Prerequisites
Wed Aug 11 01:06:01 IST 2021 - INFO - Successfully installed Amazon_Web_Services_Greengrass_Prerequisites took 16.47 seconds
Wed Aug 11 01:06:01 IST 2021 - INFO - Successfully updated status in log file for Amazon_Web_Services_Greengrass_Prerequisites
Wed Aug 11 01:06:01 IST 2021 - INFO - Imported module for K3s_Lightweight_Kubernetes is <module 'esb_install' from '/home/test/Downloads/edge_software_device_qualification/Edge_Software_Device_Qualification_3.0/K3s_Lightweight_Kubernetes/esb_install.so'>
Wed Aug 11 01:06:01 IST 2021 - INFO - Installing K3s_Lightweight_Kubernetes
Wed Aug 11 01:06:17 IST 2021 - INFO - Successfully installed K3s_Lightweight_Kubernetes took 15.41 seconds
Wed Aug 11 01:06:17 IST 2021 - INFO - Updating status in log file for K3s_Lightweight_Kubernetes as SUCCESS
Wed Aug 11 01:06:17 IST 2021 - INFO - Successfully updated status in log file for K3s_Lightweight_Kubernetes
Wed Aug 11 01:06:17 IST 2021 - INFO - Imported module for Azure_IoT_Edge_Prerequisites is <module 'esb_install' from '/home/test/Downloads/edge_software_device_qualification/Edge_Software_Device_Qualification_3.0/Azure_IoT_Edge_Prerequisites/esb_install.so'>
Wed Aug 11 01:06:17 IST 2021 - INFO - Installing Azure_IoT_Edge_Prerequisites
Wed Aug 11 01:07:08 IST 2021 - INFO - Successfully installed Azure_IoT_Edge_Prerequisites took 50.71 seconds
Wed Aug 11 01:07:08 IST 2021 - INFO - Updating status in log file for Azure_IoT_Edge_Prerequisites as SUCCESS
Wed Aug 11 01:07:08 IST 2021 - INFO - Successfully updated status in log file for Azure_IoT_Edge_Prerequisites
Wed Aug 11 01:07:08 IST 2021 - INFO - Imported module for Intel_Distribution_of_OpenVINO_toolkit_2021_3_Runtime is <module 'esb_install' from '/home/test/Downloads/edge_software_device_qualification/Edge_Software_Device_Qualification_3.0/Intel_Distribution_of_OpenVINO_toolkit_2021_3_Runtime/esb_install.so'>
Wed Aug 11 01:07:08 IST 2021 - INFO - Installing Intel_Distribution_of_OpenVINO_toolkit_2021_3_Runtime
Wed Aug 11 01:24:37 IST 2021 - INFO - Successfully installed Intel_Distribution_of_OpenVINO_toolkit_2021_3_Runtime took 17 minutes 29.78 seconds
Wed Aug 11 01:24:37 IST 2021 - INFO - Updating status in log file for Intel_Distribution_of_OpenVINO_toolkit_2021_3_Runtime as SUCCESS
Wed Aug 11 01:24:37 IST 2021 - INFO - Successfully updated status in log file for Intel_Distribution_of_OpenVINO_toolkit_2021_3_Runtime
Wed Aug 11 01:24:38 IST 2021 - INFO - Imported module for Deep_Learning_DL_Streamer_Pipelines is <module 'esb_install' from '/home/test/Downloads/edge_software_device_qualification/Edge_Software_Device_Qualification_3.0/Deep_Learning_DL_Streamer_Pipelines/esb_install.so'>
Wed Aug 11 01:24:38 IST 2021 - INFO - Installing Deep_Learning_DL_Streamer_Pipelines
Wed Aug 11 01:24:48 IST 2021 - INFO - Successfully installed Deep_Learning_DL_Streamer_Pipelines took 10.08 seconds
Wed Aug 11 01:24:48 IST 2021 - INFO - Updating status in log file for Deep_Learning_DL_Streamer_Pipelines as SUCCESS
Wed Aug 11 01:24:48 IST 2021 - INFO - Successfully updated status in log file for Deep_Learning_DL_Streamer_Pipelines
Wed Aug 11 01:24:48 IST 2021 - INFO - Imported module for Docker_Community_Edition_CE is <module 'esb_install' from '/home/test/Downloads/edge_software_device_qualification/Edge_Software_Device_Qualification_3.0/Docker_Community_Edition_CE/esb_install.so'>
Wed Aug 11 01:24:48 IST 2021 - INFO - Installing Docker_Community_Edition_CE
Wed Aug 11 01:25:50 IST 2021 - INFO - Successfully installed Docker_Community_Edition_CE took 1 minutes 2.17 seconds
Wed Aug 11 01:25:50 IST 2021 - INFO - Updating status in log file for Docker_Community_Edition_CE as SUCCESS
Wed Aug 11 01:25:50 IST 2021 - INFO - Successfully updated status in log file for Docker_Community_Edition_CE
Wed Aug 11 01:25:50 IST 2021 - INFO - Imported module for Intel_Distribution_of_OpenVINO_toolkit_2021_3_Container is <module 'esb_install' from '/home/test/Downloads/edge_software_device_qualification/Edge_Software_Device_Qualification_3.0/Intel_Distribution_of_OpenVINO_toolkit_2021_3_Container/esb_install.so'>
Wed Aug 11 01:25:50 IST 2021 - INFO - Installing Intel_Distribution_of_OpenVINO_toolkit_2021_3_Container
Wed Aug 11 01:26:38 IST 2021 - INFO - Successfully installed Intel_Distribution_of_OpenVINO_toolkit_2021_3_Container took 48.15 seconds
Wed Aug 11 01:26:38 IST 2021 - INFO - Updating status in log file for Intel_Distribution_of_OpenVINO_toolkit_2021_3_Container as SUCCESS
Wed Aug 11 01:26:38 IST 2021 - INFO - Successfully updated status in log file for Intel_Distribution_of_OpenVINO_toolkit_2021_3_Container
Wed Aug 11 01:26:38 IST 2021 - INFO - Imported module for Docker_Compose is <module 'esb_install' from '/home/test/Downloads/edge_software_device_qualification/Edge_Software_Device_Qualification_3.0/Docker_Compose/esb_install.so'>
Wed Aug 11 01:26:38 IST 2021 - INFO - Installing Docker_Compose
Wed Aug 11 01:26:43 IST 2021 - INFO - Successfully installed Docker_Compose took 4.82 seconds
Wed Aug 11 01:26:43 IST 2021 - INFO - Updating status in log file for Docker_Compose as SUCCESS
Wed Aug 11 01:26:43 IST 2021 - INFO - Successfully updated status in log file for Docker_Compose
Wed Aug 11 01:26:43 IST 2021 - INFO - Imported module for edgex_foundry is <module 'esb_install' from '/home/test/Downloads/edge_software_device_qualification/Edge_Software_Device_Qualification_3.0/edgex_foundry/esb_install.so'>
Wed Aug 11 01:26:43 IST 2021 - INFO - Installing edgex_foundry
Wed Aug 11 01:26:58 IST 2021 - INFO - Successfully installed edgex_foundry took 15.06 seconds
Wed Aug 11 01:26:58 IST 2021 - INFO - Updating status in log file for edgex_foundry as SUCCESS
Wed Aug 11 01:26:58 IST 2021 - INFO - Successfully updated status in log file for edgex_foundry
Wed Aug 11 01:26:58 IST 2021 - INFO - Imported module for ONNX_Runtime is <module 'esb_install' from '/home/test/Downloads/edge_software_device_qualification/Edge_Software_Device_Qualification_3.0/ONNX_Runtime/esb_install.so'>
Wed Aug 11 01:26:58 IST 2021 - INFO - Installing ONNX_Runtime
Wed Aug 11 01:41:44 IST 2021 - ERROR - Failed to install ONNX_Runtime took 14 minutes 46.26 seconds
Wed Aug 11 01:41:44 IST 2021 - INFO - Updating status in log file for ONNX_Runtime as FAILED
Wed Aug 11 01:41:44 IST 2021 - INFO - Successfully updated status in log file for ONNX_Runtime
Wed Aug 11 01:41:45 IST 2021 - INFO - Imported module for RI_MultiCamera_Social_Distancing is <module 'esb_install' from '/home/test/Downloads/edge_software_device_qualification/Edge_Software_Device_Qualification_3.0/RI_MultiCamera_Social_Distancing/esb_install.so'>
Wed Aug 11 01:41:45 IST 2021 - INFO - Installing RI_MultiCamera_Social_Distancing
Wed Aug 11 01:42:37 IST 2021 - INFO - Successfully installed RI_MultiCamera_Social_Distancing took 52.29 seconds
Wed Aug 11 01:42:37 IST 2021 - INFO - Updating status in log file for RI_MultiCamera_Social_Distancing as SUCCESS
Wed Aug 11 01:42:37 IST 2021 - INFO - Successfully updated status in log file for RI_MultiCamera_Social_Distancing
Wed Aug 11 01:42:37 IST 2021 - INFO - Imported module for Connect_Edge_Devices_to_Azure_IoT is <module 'esb_install' from '/home/test/Downloads/edge_software_device_qualification/Edge_Software_Device_Qualification_3.0/Connect_Edge_Devices_to_Azure_IoT/esb_install.so'>
Wed Aug 11 01:42:37 IST 2021 - INFO - Installing Connect_Edge_Devices_to_Azure_IoT
Wed Aug 11 01:43:41 IST 2021 - INFO - Successfully installed Connect_Edge_Devices_to_Azure_IoT took 1 minutes 4.28 seconds
Wed Aug 11 01:43:41 IST 2021 - INFO - Updating status in log file for Connect_Edge_Devices_to_Azure_IoT as SUCCESS
Wed Aug 11 01:43:41 IST 2021 - INFO - Successfully updated status in log file for Connect_Edge_Devices_to_Azure_IoT
Wed Aug 11 01:43:41 IST 2021 - INFO - Imported module for esdq is <module 'esb_install' from '/home/test/Downloads/edge_software_device_qualification/Edge_Software_Device_Qualification_3.0/esdq/esb_install.so'>
Wed Aug 11 01:43:41 IST 2021 - INFO - Installing esdq
Wed Aug 11 01:43:48 IST 2021 - INFO - Successfully installed esdq took 6.34 seconds
Wed Aug 11 01:43:48 IST 2021 - INFO - Updating status in log file for esdq as SUCCESS
Wed Aug 11 01:43:48 IST 2021 - INFO - Successfully updated status in log file for esdq
Wed Aug 11 01:43:49 IST 2021 - INFO - Sending installation report
Wed Aug 11 01:43:50 IST 2021 - INFO - Installation report was successfully sent.
Wed Aug 11 01:43:50 IST 2021 - INFO - Installation of package complete
$ cat /var/log/esb-cli/Edge_Software_Device_Qualification_3.0/esdq/install.log
Wed Aug 11 01:43:41 IST 2021 - INFO - ----------------------------------------
Wed Aug 11 01:43:41 IST 2021 - INFO - Starting installation ESDQ_INSTALL
Wed Aug 11 01:43:41 IST 2021 - INFO - Starting main installation ESDQ_INSTALL
Wed Aug 11 01:43:42 IST 2021 - INFO - Setting execute permission to /home/test/Downloads/edge_software_device_qualification/Edge_Software_Device_Qualification_3.0/esdq/esdq
Wed Aug 11 01:43:42 IST 2021 - INFO - ----------------------------------------
Wed Aug 11 01:43:42 IST 2021 - INFO - Starting installation ESDQ_INSTALL
Wed Aug 11 01:43:42 IST 2021 - INFO - Starting main installation ESDQ_INSTALL
Wed Aug 11 01:43:42 IST 2021 - INFO - Installing ESDQ packages: zip
premp
Also another observation I had was, even though the ONNX build fails in report I still see that ONNX test sample is passed.
JesusE_Intel
Hi premp,
Did you previously have ONNX installed on your Ubuntu 18.04 system? Is this system a fresh Ubuntu install?
Also, it looks like you are using ESDQ 3.0, do you see the same behavior using the latest ESDQ 4.0 release?
Jesus
