Edge Software Catalog
471 Discussions
Error receiving message after registering as a new subscriber
Louis8
I am trying to receive messages sent from Publisher in another container by registering a subscriber. However, the error message below continues to occur. Is there any solution?
ERROR:proto_zmq_subscriber_new:685: Failed to create URI for topic: start_inferencing
ERROR : {} : root : [server.pyin line : [189] : Failed to subscribe to topic "start_inferencing": Failed to subscribe to topic
======== code ==========
sub_msgbus = mb.MsgbusContext(msgbus_cfg)
try:
   subscriber = sub_msgbus.new_subscriber(topic)
   if subscriber is not None:
         metadata, _ = subscriber.recv() self.logger.info(f'[INFO] Control PLC Sub - Receiving:  {metadata}')
   else:
        self.logger.error(f'[ERROR] Subscriber is None. Subscription might have failed.')
except eii.exc.MessageBusError as e: # Log or print the detailed error information
   self.logger.error(f'Failed to subscribe to topic "{topic}": {e}')
JesusE_Intel
Hi Louis8,
Apologies for the delay in my response, could you please share the path/filename to all the files you modified? Where you able to successfully send/receive messages using the steps in my other thread before registering a new subscriber? In the meantime, I am setting up an environment using the latest Edge Insights for Industrial v4.1 to run some tests.
Jesus
Louis8
Where I tested it, I put the above code into callback() of server.py.
JesusE_Intel
Apologies for the delay in my response, I have reached out to the development team for further assistance.
JesusE_Intel
Hi Louis8,
Apologies for the delay in our response. We recently released a new version of the software. Would it be possible for you to test on the latest release and create a new issue if you continue to encounter the same error?
Additional details can be found in the documentation: Advanced Guide — Intel® Edge Insights System Documentation v1.0 documentation
Jesus
